Switch IC
Would anyone be able to recommend a switch I can control
with the Basic Stamp.
I have a module that controls a RF antennae, the antennae
connects to the module via two terminals.
I would like to be able to use some sort of switch so the stamp
can direct the signal to any ONE of four antennae's at any ONE time.
Many thanks
Barney
Many thanks
Barney
independently. Connect the wiper of all 4 switches to your module, and
each antenna to one pole (normally OFF) of each of the 4 switches. Use
a Stamp pin as output to each switch to control which switch gets set to
ON.
Dennis
Original Message
From: Barney [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9z1ncSRu3m1fhX6S8vwHZIV7FZzdJJ6pm2FwmReJRxD-hZ8iT9PfJPxCgJYggYxD8dK2_L9HxTvvvJBvgTrupX3Cog]developer@e...[/url
Sent: Saturday, February 16, 2002 8:57 PM
To: basic stamp
Subject: [noparse][[/noparse]basicstamps] Switch IC
I have a module that controls a RF antennae, the antennae connects to
I would like to be able to use some sort of switch so the stamp can
Many thanks
Barney
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Original Message
To: "basic stamp" <basicstamps@yahoogroups.com>
Sent: Saturday, February 16, 2002 8:56 PM
> Many thanks
> Barney
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Stephen, I am using a Texas Instruments Microreader
operating at 134.2 Khz ?
http://www.ti.com/tiris/docs/products/products.htm#readers
Barney
> From: "Stephen H Chapman" <chapman@t...>
> What Radio Frequency range are you trying to switch?
Original Message
> From: "Barney" <developer@e...>
>> Many thanks
>> Barney
> from the same email address that you subscribed. Text in the Subject and Body
