Switch IC — Parallax Forums
Switch IC
edited 2002-02-18 08:15 in General Discussion
Would anyone be able to recommend a switch I can control
with the Basic Stamp.
I have a module that controls a RF antennae, the antennae
connects to the module via two terminals.
I would like to be able to use some sort of switch so the stamp
can direct the signal to any ONE of four antennae's at any ONE time.
Many thanks
Barney
    edited 2002-02-17 22:19
    The Maxim 333CPP is a 20-pin DIP with 4 logic-level switches controlled
    independently. Connect the wiper of all 4 switches to your module, and
    each antenna to one pole (normally OFF) of each of the 4 switches. Use
    a Stamp pin as output to each switch to control which switch gets set to
    ON.
    Dennis
    From: Barney [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9z1ncSRu3m1fhX6S8vwHZIV7FZzdJJ6pm2FwmReJRxD-hZ8iT9PfJPxCgJYggYxD8dK2_L9HxTvvvJBvgTrupX3Cog]developer@e...[/url
    Sent: Saturday, February 16, 2002 8:57 PM
    To: basic stamp
    Subject: [noparse][[/noparse]basicstamps] Switch IC
    I have a module that controls a RF antennae, the antennae connects to
    I would like to be able to use some sort of switch so the stamp can
    Many thanks
    Barney
    Your use of Yahoo! Groups is subject to
    edited 2002-02-18 01:01
    What Radio Frequency range are you trying to switch?
    To: "basic stamp" <basicstamps@yahoogroups.com>
    Sent: Saturday, February 16, 2002 8:56 PM
    > Many thanks
    > Barney
    Thanks Dennis for your info on the Maxim 333CPP.
    Stephen, I am using a Texas Instruments Microreader
    operating at 134.2 Khz ?
    http://www.ti.com/tiris/docs/products/products.htm#readers
    Barney
    > From: "Stephen H Chapman" <chapman@t...>
    > From: "Barney" <developer@e...>
    >> Many thanks
    >> Barney
