Serial Input Weirdness
I'm wondering if anyone could help me with some code. I am trying to send
serial data to my BS2 from my PC. My program waits for the ASCII string qwerty
then saves the following 8 bytes and debugs their values. When I send
qwerty12345678 from the PC, the debug shows garbage. But if I send qwerty, then
send 12345678 seperatly it works. Why?
here's my program:
begin:
serString var byte(8)
serString(7) = 0
serin 15,16468,[noparse][[/noparse]wait ("qwerty"),str serString\8]
debug str serString
goto begin
Thanks for any help.
-Dan
here's my program:
begin:
serString(7) = 0
debug str serString
goto begin
-Dan
of processing time. When you're sending the packets separately, SERIN has
time enough to get ready to receive the "12345678" part. You might want to
adjust your PC end to add a bit of pacing between characters.
-- Jon Williams
-- Parallax
In a message dated 1/10/02 6:17:41 PM Central Standard Time,
gliebetronics@h... writes:
> qwerty then saves the following 8 bytes and debugs their values. When I
> send qwerty12345678 from the PC, the debug shows garbage. But if I send
> qwerty, then send 12345678 seperatly it works. Why?
> here's my program:
> begin:
> serString(7) = 0
> debug str serString
> goto begin
> -Dan
so I think I'll explain my whole situation and hopefully someone out there
will have some brilliant idea which I have not thought of yet. What I'm
trying to do is send 8 numbers from a PC to the BS2. Each number is between
0 and 255. The format in which I have been trying to send the numbers is
A#B#C#D#E#F#G#H#. So a sample of potential data is like
A1B40C255D0E30F100G1H255. I was trying to use a serin command with Wait's
in it to wait for each Letter then save the numbers in appropreatly named
byte size variables, A, B, C... I keep getting weird results like having
to resend the data many times or at least twice to successfully recieve all
the data. I've tried Strings and Sending the data seperatly and lower Baud
rates, All woth no luck. :-/ Anybody know any tried and true methods of
programming for such a situation as this? Some examples would be greatly
appreciated. thanks.
-Dan
any serial modifiers (like WAIT and SKIP) since they require extra processing
time. You might find something helpful in a project I did called EEMOVER.
It allowed me to use VB to change a big block of data in the Stamp's EE. You
can find it at:
http://members.aol.com/jonwms/stamps/eemover.zip
-- Jon Williams
-- Parallax
In a message dated 1/11/02 12:42:44 AM Central Standard Time,
> Hi. I posted earlier and I did get a reply but it didn't really help me out
You should be able to read binary numbers directly.
Take some trigger value to wait for, like a '*' then
A var byte
B var byte
etc.
Serin pin,baud,[noparse][[/noparse]wait "*",dec A, dec B, dec C, dec D, dec E, dec F, dec G,
dec H]
Send your data like
"*,001,002,003,004,005,006,007,008" with comma's as seperators (without the
quotes of course)
If you use fixed length numbers (like always 3 digits) you can use dec3
instead of dec in serin.
That should work.
Regards peter
Oorspronkelijk bericht
Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=StD_lnTX7mhrRK5hbETw2VoJkOmMZhMzqEV3sVB1Y7h2XgB51OZgpHHFY9lFgNopKRXpXP2rScYLjS2Xz844nzwq]gliebetronics@h...[/url
Verzonden: donderdag 10 januari 2002 22:39
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Serial Input Weirdness
-Dan
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
serin 15,16780, [noparse][[/noparse]Wait ("start"), A, B]
I can send from the PC (without quotes) "start26".
I debug A and B and they are indeed 2 and 6. However, if I use this line
with the DEC before each variable:
serin 15,16780, [noparse][[/noparse]Wait ("start"), dec A, dec B]
If I send (without quotes) "start123,456" I MUST send the serial string
TWICE for some odd reason for the BS2 to continue on and debug the values.
Without the DEC there, I can't have #s larger than one digit, I can't have A
= 255 for instance. Why does it always seem to get hung up when I use DEC?
-Dan
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, January 11, 2002 8:19 AM
Subject: RE: [noparse][[/noparse]basicstamps] Serial Input Weirdness
> Hi,
> A var byte
> B var byte
> etc.
> dec H]
> Send your data like
the
> quotes of course)
> That should work.
> Regards peter
> Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dX0GM-jHD6OiKetyxuM3JUiZvH_Dd9xZV68-7H1gZ0dNPCFGJsj5FTV1HTc0SilIt21vxgMgtY-yptSF6Jc7aF-G7A]gliebetronics@h...[/url
out
between
all
Baud
> -Dan
"start123,255" since my variables are bytes.
-Dan
Original Message
Sent: Friday, January 11, 2002 10:36 AM
Subject: Re: [noparse][[/noparse]basicstamps] Serial Input Weirdness
> The strange part that I don't understand is that if I use this:
A
DEC?
> -Dan
Original Message
> From: "peter verkaik" <peterverkaik@b...>
> > Hi,
> > A var byte
> > B var byte
> > etc.
G,
> > dec H]
> > Send your data like
> the
> > quotes of course)
> > That should work.
> > Regards peter
> > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ss5IoKPmAVFl9H4MH3F0gnwxI7UsEtMKymEi_frYuL3eekHPTza4Csp3AaDzTn9ZiRvJLPzidefwOmxokpskxXrH]gliebetronics@h...[/url
> out
there
> between
is
Wait's
named
having
> all
> Baud
greatly
> > -Dan
and
and
I do a similar thing with a series of numbers, some of different lengths as:
GetData:
Serin 15, 84, [noparse][[/noparse]wait("U"), dec1 Tr, dec4 Size, dec4 Mask, dec5 LCD,
dec5 Lens, dec4 Pre, dec4 Post]
Debug cls
Debug cr, "Transport ", dec1 Tr
Debug cr, "Size ", dec4 Size
Debug cr, "Mask ", dec4 Mask
Debug cr, "LCD ", dec5 LCD
Debug cr, "Lens ", dec5 Lens
Debug cr, "Pre ", dec4 Pre
Debug cr, "Post ", dec4 Post
snip.....
As you can see, each piece of data is predefined as to how long it is expected
to be. If you know all of your
data is within 255, then of course you can just set them up as byte variables,
but in my case, several of
them need 5 bytes, and as in the case of the Tr variable, I did that to save
space.
The debug list simply prints them all out so that I can see them whilst
debugging.
This has worked very solidly for me.
Good luck
Russ
| > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=062lYUmhBQmsAh31-imgdYqjLHw1cm84HWFW_03yDj0vNwmmDgJabR1N2KF08Xfq3SJtsGcrZnuXFp82ZgN-ElP6]gliebetronics@h...[/url
| out
| between
snip...
takes additional processing overhead.
Another note is that you must send a non-numeric character between each
number when using DEC. In your first example, the Stamp saw "start" then but
the next byte into "A" and the second byte into "B." If you check carefully,
what you actually received was "2" and "6" (characters, not numbers).
On your second example, try sending the string "start 123,456<CR>" (note that
<CR> is meant to be #13 [noparse][[/noparse]carriage return]) and put some pacing between the
characters (see Jan Axelson's book 'Serial Port Complete' for VB code to do
this).
-- Jon Williams
-- Parallax
In a message dated 1/11/02 12:41:33 PM Central Standard Time,
the data.
Chris
Original Message
Sent: Saturday, January 12, 2002 2:36 AM
A
DEC?
> -Dan
Original Message
> > Hi,
> > A var byte
> > B var byte
> > etc.
G,
> > dec H]
> > Send your data like
> the
> > quotes of course)
> > That should work.
> > Regards peter
> > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Zgj5cbKpwEbScwms0TQFQavYYAGinZTag3Wx8gOcsp-LD9L8MH-OptmwL-XORCVZeZeGtzSjrlnmm6o-IqNg]gliebetronics@h...[/url
> out
there
> between
is
Wait's
named
having
> all
> Baud
greatly
> > -Dan
and
and
