Serial Input Weirdness — Parallax Forums
edited 2002-01-11 23:21 in General Discussion
I'm wondering if anyone could help me with some code. I am trying to send
serial data to my BS2 from my PC. My program waits for the ASCII string qwerty
then saves the following 8 bytes and debugs their values. When I send
qwerty12345678 from the PC, the debug shows garbage. But if I send qwerty, then
send 12345678 seperatly it works. Why?
here's my program:
begin:
serString var byte(8)
serString(7) = 0
serin 15,16468,[noparse][[/noparse]wait ("qwerty"),str serString\8]
debug str serString
goto begin
Thanks for any help.
-Dan
    edited 2002-01-11 01:33
    Remember that using the SERIN modifiers (like WAIT and SKIP) requires a bit
    of processing time. When you're sending the packets separately, SERIN has
    time enough to get ready to receive the "12345678" part. You might want to
    adjust your PC end to add a bit of pacing between characters.
    -- Jon Williams
    -- Parallax
    In a message dated 1/10/02 6:17:41 PM Central Standard Time,
    gliebetronics@h... writes:
    > qwerty then saves the following 8 bytes and debugs their values. When I
    > send qwerty12345678 from the PC, the debug shows garbage. But if I send
    > qwerty, then send 12345678 seperatly it works. Why?
    > here's my program:
    > begin:
    > serString(7) = 0
    > debug str serString
    > goto begin
    > -Dan
    edited 2002-01-11 06:39
    Hi. I posted earlier and I did get a reply but it didn't really help me out
    so I think I'll explain my whole situation and hopefully someone out there
    will have some brilliant idea which I have not thought of yet. What I'm
    trying to do is send 8 numbers from a PC to the BS2. Each number is between
    0 and 255. The format in which I have been trying to send the numbers is
    A#B#C#D#E#F#G#H#. So a sample of potential data is like
    A1B40C255D0E30F100G1H255. I was trying to use a serin command with Wait's
    in it to wait for each Letter then save the numbers in appropreatly named
    byte size variables, A, B, C... I keep getting weird results like having
    to resend the data many times or at least twice to successfully recieve all
    the data. I've tried Strings and Sending the data seperatly and lower Baud
    rates, All woth no luck. :-/ Anybody know any tried and true methods of
    programming for such a situation as this? Some examples would be greatly
    appreciated. thanks.
    -Dan
    edited 2002-01-11 13:28
    If you're always sending eight bytes, send them in the same order and remove
    any serial modifiers (like WAIT and SKIP) since they require extra processing
    time. You might find something helpful in a project I did called EEMOVER.
    It allowed me to use VB to change a big block of data in the Stamp's EE. You
    can find it at:
    http://members.aol.com/jonwms/stamps/eemover.zip
    -- Jon Williams
    -- Parallax
    In a message dated 1/11/02 12:42:44 AM Central Standard Time,
    edited 2002-01-11 16:19
    You should be able to read binary numbers directly.
    Take some trigger value to wait for, like a '*' then
    A var byte
    B var byte
    etc.
    Serin pin,baud,[noparse][[/noparse]wait "*",dec A, dec B, dec C, dec D, dec E, dec F, dec G,
    dec H]
    Send your data like
    "*,001,002,003,004,005,006,007,008" with comma's as seperators (without the
    quotes of course)
    If you use fixed length numbers (like always 3 digits) you can use dec3
    instead of dec in serin.
    That should work.
    Regards peter
    Oorspronkelijk bericht
    Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=StD_lnTX7mhrRK5hbETw2VoJkOmMZhMzqEV3sVB1Y7h2XgB51OZgpHHFY9lFgNopKRXpXP2rScYLjS2Xz844nzwq]gliebetronics@h...[/url
    Verzonden: donderdag 10 januari 2002 22:39
    Aan: basicstamps@yahoogroups.com
    Onderwerp: [noparse][[/noparse]basicstamps] Serial Input Weirdness
    -Dan
    edited 2002-01-11 18:36
    The strange part that I don't understand is that if I use this:
    serin 15,16780, [noparse][[/noparse]Wait ("start"), A, B]
    I can send from the PC (without quotes) "start26".
    I debug A and B and they are indeed 2 and 6. However, if I use this line
    with the DEC before each variable:
    serin 15,16780, [noparse][[/noparse]Wait ("start"), dec A, dec B]
    If I send (without quotes) "start123,456" I MUST send the serial string
    TWICE for some odd reason for the BS2 to continue on and debug the values.
    Without the DEC there, I can't have #s larger than one digit, I can't have A
    = 255 for instance. Why does it always seem to get hung up when I use DEC?
    -Dan
    Sent: Friday, January 11, 2002 8:19 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Serial Input Weirdness
    > Hi,
    > A var byte
    > B var byte
    > etc.
    > dec H]
    > Send your data like
    the
    > quotes of course)
    > That should work.
    > Regards peter
    > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dX0GM-jHD6OiKetyxuM3JUiZvH_Dd9xZV68-7H1gZ0dNPCFGJsj5FTV1HTc0SilIt21vxgMgtY-yptSF6Jc7aF-G7A]gliebetronics@h...[/url
    out
    between
    all
    Baud
    > -Dan
    edited 2002-01-11 18:42
    oops, I made a small typO. Where I say "start123,456" it should be
    "start123,255" since my variables are bytes.
    -Dan
    Sent: Friday, January 11, 2002 10:36 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Serial Input Weirdness
    A
    DEC?
    > -Dan
    > From: "peter verkaik" <peterverkaik@b...>
    > > Hi,
    > > A var byte
    > > B var byte
    > > etc.
    G,
    > > dec H]
    > > Send your data like
    > the
    > > quotes of course)
    > > That should work.
    > > Regards peter
    > > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ss5IoKPmAVFl9H4MH3F0gnwxI7UsEtMKymEi_frYuL3eekHPTza4Csp3AaDzTn9ZiRvJLPzidefwOmxokpskxXrH]gliebetronics@h...[/url
    > out
    there
    > between
    is
    Wait's
    named
    having
    > all
    > Baud
    greatly
    > > -Dan
    and
    and
    edited 2002-01-11 18:48
    Hi Dan,
    I do a similar thing with a series of numbers, some of different lengths as:
    GetData:
    Serin 15, 84, [noparse][[/noparse]wait("U"), dec1 Tr, dec4 Size, dec4 Mask, dec5 LCD,
    dec5 Lens, dec4 Pre, dec4 Post]
    Debug cls
    Debug cr, "Transport ", dec1 Tr
    Debug cr, "Size ", dec4 Size
    Debug cr, "Mask ", dec4 Mask
    Debug cr, "LCD ", dec5 LCD
    Debug cr, "Lens ", dec5 Lens
    Debug cr, "Pre ", dec4 Pre
    Debug cr, "Post ", dec4 Post
    snip.....
    As you can see, each piece of data is predefined as to how long it is expected
    to be. If you know all of your
    data is within 255, then of course you can just set them up as byte variables,
    but in my case, several of
    them need 5 bytes, and as in the case of the Tr variable, I did that to save
    space.
    The debug list simply prints them all out so that I can see them whilst
    debugging.
    This has worked very solidly for me.
    Good luck
    Russ
    | > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=062lYUmhBQmsAh31-imgdYqjLHw1cm84HWFW_03yDj0vNwmmDgJabR1N2KF08Xfq3SJtsGcrZnuXFp82ZgN-ElP6]gliebetronics@h...[/url
    | out
    | between
    snip...
    edited 2002-01-11 19:12
    DEC is another modifier -- it converts string dat to numeric data, so it
    takes additional processing overhead.
    Another note is that you must send a non-numeric character between each
    number when using DEC. In your first example, the Stamp saw "start" then but
    the next byte into "A" and the second byte into "B." If you check carefully,
    what you actually received was "2" and "6" (characters, not numbers).
    On your second example, try sending the string "start 123,456<CR>" (note that
    <CR> is meant to be #13 [noparse][[/noparse]carriage return]) and put some pacing between the
    characters (see Jan Axelson's book 'Serial Port Complete' for VB code to do
    this).
    -- Jon Williams
    -- Parallax
    In a message dated 1/11/02 12:41:33 PM Central Standard Time,
    Try slowing down the baud rate, it may be too fast for the bs2 to receive
    the data.
    Chris
    Sent: Saturday, January 12, 2002 2:36 AM
    A
    DEC?
    > -Dan
    > > Hi,
    > > A var byte
    > > B var byte
    > > etc.
    G,
    > > dec H]
    > > Send your data like
    > the
    > > quotes of course)
    > > That should work.
    > > Regards peter
    > > Van: Daniel Gliebe [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Zgj5cbKpwEbScwms0TQFQavYYAGinZTag3Wx8gOcsp-LD9L8MH-OptmwL-XORCVZeZeGtzSjrlnmm6o-IqNg]gliebetronics@h...[/url
    > out
    there
    > between
    is
    Wait's
    named
    having
    > all
    > Baud
    greatly
    > > -Dan
    and
    and
