Driving A Selonoid
Can anyone help me with project I am doing driving some hyd. solonoids with a
stamp.
The sol. operate at 12-14v dc.
the coil resistance is 7 ohm.
I would like to do it with trans.
I think I want to use a 2n2222 to drive a PNP
Thanks in advance.
also call directly @ 888-920-7746
ask for shannon
stamp.
Thanks in advance.
ask for shannon
a relay and a driver transistor controlled by the stamp. This will also
isolate the transient voltages developed from the solenoid when you stop the
current flow through the coil. The relay contacts should be rated to carry 5
amps.
Hope this helps, Steve
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, November 13, 2001 11:06 AM
Subject: [noparse][[/noparse]basicstamps] Driving A Selonoid
with a
> stamp.
> Thanks in advance.
> ask for shannon
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
there are other factors to consider. The IPS511G requires a PCB to mount
this SOIC device. The Switched output of this device is not totally isolated
from the input to the device. From their document, "The double level shifter
allows large offsets between the logic ground and the load ground." There
is still voltage present at the output even when the device is turned off.
This problem does not exist with a relay. It gives complete circuit
isolation between the driving source and the load.
Original Message
Sent: Tuesday, November 13, 2001 11:59 PM
Subject: Re: [noparse][[/noparse]basicstamps] Driving A Selonoid
> I would recommend you consider a device such as:
> http://www.irf.com/product-info/datasheets/data/ips511g.pdf
> Available from Digi-Key
> Part #:
> IPS511GTR-ND
> Price: $1.33
> regards,
> Leroy
with a
> > stamp.
> > Thanks in advance.
> > ask for shannon
and Body of the message will be ignored.
solonoids with a
> stamp.
> Thanks in advance.
> ask for shannon
Take a look at the IPS021 - about $1.50 at digikey. Fully protected
against overcurrent and built in transient absorption. Driving a
relay has all the same problems as driving a solenoid, except the
current is lower, so why add that into the mix unless you're really
concerned about the isolation?
Chuck
a much larger trans. and dont forget about the breakdown voltage from the
solinoid coil after it is swiched off. A relay negates all that. But you
may still need to put a cap. across the solinoid leads to eliminate any
noise from it .
On Tue, 13 Nov 2001 14:06:13 EST moretraction@a... writes:
> solonoids with a
> stamp.
> Thanks in advance.
> ask for shannon
> Subject and Body of the message will be ignored.
consideration. Look on digi-key.com and search for high or low side
drivers. I would be happy to design and build a circuit to your
specifications, but I couldn't do it for free. There are other driver
units available at digi-key.com that don't require a circuit board.
regards,
Leroy
Stephen H Chapman wrote:
> The device you recommend will theoretically satisfy the requirement. However
Original Message
> From: "Leroy Hall" <leroy@f...>
> > Part #:
> > IPS511GTR-ND
> > Price: $1.33
> > regards,
> > Leroy
> with a
> > > stamp.
> > > Thanks in advance.
> > > ask for shannon
> from the same email address that you subscribed. Text in the Subject and Body
Part #:
IPS511GTR-ND
Price: $1.33
regards,
Leroy
> stamp.
> Thanks in advance.
> ask for shannon
