Driving A Selonoid — Parallax Forums
Driving A Selonoid
edited 2001-11-14 07:59 in General Discussion
Can anyone help me with project I am doing driving some hyd. solonoids with a
stamp.
The sol. operate at 12-14v dc.
the coil resistance is 7 ohm.
I would like to do it with trans.
I think I want to use a 2n2222 to drive a PNP
Thanks in advance.
also call directly @ 888-920-7746
ask for shannon
    edited 2001-11-13 19:51
    The solenoid you are driving takes about 2 amps of current. Suggest you use
    a relay and a driver transistor controlled by the stamp. This will also
    isolate the transient voltages developed from the solenoid when you stop the
    current flow through the coil. The relay contacts should be rated to carry 5
    amps.
    Hope this helps, Steve
    Sent: Tuesday, November 13, 2001 11:06 AM
    Subject: [noparse][[/noparse]basicstamps] Driving A Selonoid
    with a
    > stamp.
    > Thanks in advance.
    > ask for shannon
    edited 2001-11-13 20:55
    The device you recommend will theoretically satisfy the requirement. However
    there are other factors to consider. The IPS511G requires a PCB to mount
    this SOIC device. The Switched output of this device is not totally isolated
    from the input to the device. From their document, "The double level shifter
    allows large offsets between the logic ground and the load ground." There
    is still voltage present at the output even when the device is turned off.
    This problem does not exist with a relay. It gives complete circuit
    isolation between the driving source and the load.
    Sent: Tuesday, November 13, 2001 11:59 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Driving A Selonoid
    > I would recommend you consider a device such as:
    > http://www.irf.com/product-info/datasheets/data/ips511g.pdf
    > Available from Digi-Key
    > Part #:
    > IPS511GTR-ND
    > Price: $1.33
    > regards,
    > Leroy
    with a
    > > stamp.
    > > Thanks in advance.
    > > ask for shannon
    edited 2001-11-13 21:47
    solonoids with a
    > stamp.
    > Thanks in advance.
    > ask for shannon
    Take a look at the IPS021 - about $1.50 at digikey. Fully protected
    against overcurrent and built in transient absorption. Driving a
    relay has all the same problems as driving a solenoid, except the
    current is lower, so why add that into the mix unless you're really
    concerned about the isolation?
    Chuck
    edited 2001-11-14 03:40
    You would be better off using a relay . 14v /7ohms = 2 amps You will need
    a much larger trans. and dont forget about the breakdown voltage from the
    solinoid coil after it is swiched off. A relay negates all that. But you
    may still need to put a cap. across the solinoid leads to eliminate any
    noise from it .
    On Tue, 13 Nov 2001 14:06:13 EST moretraction@a... writes:
    > solonoids with a
    > stamp.
    > Thanks in advance.
    > ask for shannon
    edited 2001-11-14 04:53
    If total isolation is required, then an opto coupler might be a
    consideration. Look on digi-key.com and search for high or low side
    drivers. I would be happy to design and build a circuit to your
    specifications, but I couldn't do it for free. There are other driver
    units available at digi-key.com that don't require a circuit board.
    regards,
    Leroy
    > From: "Leroy Hall" <leroy@f...>
    > > Part #:
    > > IPS511GTR-ND
    > > Price: $1.33
    > > regards,
    > > Leroy
    > with a
    > > > stamp.
    > > > Thanks in advance.
    > > > ask for shannon
    Part #:
    IPS511GTR-ND
    Price: $1.33
    regards,
    Leroy
    > stamp.
    > Thanks in advance.
    > ask for shannon
