RPM of a RC engine ?
Hello !
Anyone who can tell me how to make a basicstamp application to
monitor the RPM of a RC plane engine.
Joakim
Joakim
one way is to use an IR transceiver placed close together, the IR would
reflect off the propeller back to receiver
I've seen this kind of setup on equipment I have at work
I think Rainbow makes a IR transceiver kit that might get you started
On Sun, 04 Nov 2001 09:57:41 -0000 joakim.lejon@t... writes:
> Hello !
> Thanks
> Joakim
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
small amplifier) used in some RC gear. You may want to run it into a
555 one-shot to clean up the signal. Small speakers tend to be useful
as an input device also.
joakim.lejon@t... wrote:
> Hello !
> Thanks
> Joakim
> from the same email address that you subscribed. Text in the Subject and Body
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
photosensors from several manufacturers and they are pretty cheap. I
use one in a photoprocessor (no, the IR doesn't bother the
photopaper!) These devices are IR diode transmitter and receiver in
one package. You can use these to read pulse width or frequency.
