Measuring pulse lengths
Hi all,
I would like to know how to measure low pulses for lengths of 0.2,
0.5, and 0.8 s. I looked at the PULSIN command and immediately ran
into a problem. I have a BS2 and BS2SX. The limits for maximum pulse
with according to the manual are 131.07 ms and 52.428 ms
respectively. Thus, I would like know if there are any other ways of
measuring pulses. As always, any input would be appreciated.
Sincerely,
RP
Sincerely,
RP
Lawrence C. Windrem
lwindrem@p...
lwindrem@g...
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, October 26, 2001 3:53 PM
Subject: [noparse][[/noparse]basicstamps] Measuring pulse lengths
> Hi all,
> Sincerely,
> RP
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
you the difference between .2, .5, and .8 then you could use a if or while
statement with a pause and a for next this is very rough but the idea is
here. now if your pause is set correctly you will get readings of 2, 5, or 8
with debug
looking:
if pin 1 = 1 then timing
goto looking
timing:
for i = 1 to 10
pause 100 'this is a 100ms pause it will need to be shorter to give the
count you need
if pin 1 = 0 then reading
next i
goto overflow
reading:
debug ? i
goto looking
overflow:
debug ? "too much time
goto looking
Original Message
Sent: October 26, 2001 12:53 PM
| Hi all,
| Sincerely,
| RP
pin1 = 0 then timing and the second if statement to if pin 1 = 1
Original Message
Sent: October 27, 2001 9:13 AM
Subject: Re: [noparse][[/noparse]basicstamps] Measuring pulse lengths
| IF you do not need to do other tasks and the measurement only needs to
tell
while
8
| with debug
| looking:
| goto looking
| timing:
| for i = 1 to 10
| count you need
| next i
| goto overflow
| reading:
| debug ? i
| goto looking
| overflow:
| goto looking
Original Message
| | Hi all,
| | Sincerely,
| | RP
and
