Measuring pulse lengths — Parallax Forums
edited 2001-10-27 17:47 in General Discussion
Hi all,
I would like to know how to measure low pulses for lengths of 0.2,
0.5, and 0.8 s. I looked at the PULSIN command and immediately ran
into a problem. I have a BS2 and BS2SX. The limits for maximum pulse
with according to the manual are 131.07 ms and 52.428 ms
respectively. Thus, I would like know if there are any other ways of
measuring pulses. As always, any input would be appreciated.
Sincerely,
RP
    edited 2001-10-26 21:59
    Use a Counter and Loop Then pulsin
    Lawrence C. Windrem
    lwindrem@p...
    lwindrem@g...
    Sent: Friday, October 26, 2001 3:53 PM
    Subject: [noparse][[/noparse]basicstamps] Measuring pulse lengths
    > Hi all,
    > Sincerely,
    > RP
    edited 2001-10-27 17:13
    IF you do not need to do other tasks and the measurement only needs to tell
    you the difference between .2, .5, and .8 then you could use a if or while
    statement with a pause and a for next this is very rough but the idea is
    here. now if your pause is set correctly you will get readings of 2, 5, or 8
    with debug
    looking:
    if pin 1 = 1 then timing
    goto looking
    timing:
    for i = 1 to 10
    pause 100 'this is a 100ms pause it will need to be shorter to give the
    count you need
    if pin 1 = 0 then reading
    next i
    goto overflow
    reading:
    debug ? i
    goto looking
    overflow:
    debug ? "too much time
    goto looking
    Sent: October 26, 2001 12:53 PM
    | Hi all,
    | Sincerely,
    | RP
    I missed your low pulse requirement so change the first if statement to if
    pin1 = 0 then timing and the second if statement to if pin 1 = 1
    Sent: October 27, 2001 9:13 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Measuring pulse lengths
    tell
    while
    8
    | with debug
    | looking:
    | goto looking
    | timing:
    | for i = 1 to 10
    | count you need
    | next i
    | goto overflow
    | reading:
    | debug ? i
    | goto looking
    | overflow:
    | goto looking
    | | Hi all,
    | | Sincerely,
    | | RP
    and
