jumper wires for pins
use .025 square headers 100 0n center just break them off solder some wire
shrink tubing that's all there is to it.
hope this helps
regards
Victor Faria
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, October 13, 2001 1:25 PM
Subject: [noparse][[/noparse]basicstamps] jumper wires for pins
> Does anyone know a place to buy jumper wires to connect those pins
> that come off a BS2 carrier board?
> Basically it's a six inch wire with two plastic squares on each end
> housing a little metal circle that goes around the pin. It seems like
> something I should be able to find anywhere, but I've looked at the
> electronics store, Jameco, etc.
> Thanks,
> Mark
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
hope this helps
regards
Victor Faria
Original Message
> Thanks,
> Mark
right from the Jameco catalog,
.100 male headers .025 square single row (break away)
jameco p#160881 that's a 40 pin header they also have smaller ones but the
price is .39 each header
then you just break up these headers into singles and join them with a small
stranded wire .
and you have your jumper.
regards
victor Faria
Original Message
Sent: Saturday, October 13, 2001 4:29 PM
Subject: Re: [noparse][[/noparse]basicstamps] jumper wires for pins
wire
> hmmm, what's .025 square headers 100 On center and where do I get it?
> I'm looking for an off the shelf solution if possible..
> >hope this helps
> >regards
> >Victor Faria
Original Message
> >From: "markallen" <markallen@c...>
> > > Thanks,
> > > Mark
and
> >Subject and Body of the message will be ignored.
Mark
>hope this helps
>regards
>Victor Faria
Original Message
> > Thanks,
> > Mark
wires plug in to? For the female sockets I used a standard IC socket, and
cut it in half, I got 2 rows of female sockets I could then use.
If you want jumper wires you could get one of those radio shack breadboard
kits with multiple length wires in the kit.
.100 on center is a standard spacing for components. If you look at a
breadboard or a wire wrap board or a drilled PC board as sold by radio shack
the holes are on .1 centers. 10 holes per inch it means.
-kerry
>>hope this helps
>>regards
>>Victor Faria
Original Message
>> > Thanks,
>> > Mark
Sincerely
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1132
