jumper wires for pins — Parallax Forums
edited 2001-10-13 21:42 in General Discussion
use .025 square headers 100 0n center just break them off solder some wire
shrink tubing that's all there is to it.
hope this helps
regards
Victor Faria
Sent: Saturday, October 13, 2001 1:25 PM
Subject: [noparse][[/noparse]basicstamps] jumper wires for pins
> Does anyone know a place to buy jumper wires to connect those pins
> that come off a BS2 carrier board?
> Basically it's a six inch wire with two plastic squares on each end
> housing a little metal circle that goes around the pin. It seems like
> something I should be able to find anywhere, but I've looked at the
> electronics store, Jameco, etc.
> Thanks,
> Mark
    edited 2001-10-13 15:20
    OK,let me try this again.
    right from the Jameco catalog,
    .100 male headers .025 square single row (break away)
    jameco p#160881 that's a 40 pin header they also have smaller ones but the
    price is .39 each header
    then you just break up these headers into singles and join them with a small
    stranded wire .
    and you have your jumper.
    regards
    victor Faria
    Sent: Saturday, October 13, 2001 4:29 PM
    Subject: Re: [noparse][[/noparse]basicstamps] jumper wires for pins
    wire
    > hmmm, what's .025 square headers 100 On center and where do I get it?
    > I'm looking for an off the shelf solution if possible..
    > >hope this helps
    > >regards
    > >Victor Faria
    > >From: "markallen" <markallen@c...>
    > > > Thanks,
    > > > Mark
    and
    > >Subject and Body of the message will be ignored.
    edited 2001-10-13 18:25
    Mark
    edited 2001-10-13 21:29
    >hope this helps
    >regards
    >Victor Faria
    > > Thanks,
    > > Mark
    Victor are you looking for jumper wires, or the female sockets that the
    wires plug in to? For the female sockets I used a standard IC socket, and
    cut it in half, I got 2 rows of female sockets I could then use.
    If you want jumper wires you could get one of those radio shack breadboard
    kits with multiple length wires in the kit.
    .100 on center is a standard spacing for components. If you look at a
    breadboard or a wire wrap board or a drilled PC board as sold by radio shack
    the holes are on .1 centers. 10 holes per inch it means.
    -kerry
    >>hope this helps
    >>regards
    >>Victor Faria
    >> > Thanks,
    >> > Mark
    Sincerely
    Kerry
    Admin@M...
    WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
    Kerry Barlow
    p.o. box 21
    kirkwood ny
    13795
    607-775-1132
