AW: [basicstamps] Editor Version 1.2
sorry, wrong.
I changed my system according to Rodent's advice and still get the same
mistake. :-(
have a nice day, uli
Urspr
mistake. :-(
Urspr
You did go into the REGIONAL SETTINGS in control panel and change it there?
In Win98 SE there is a setting on the first screen that lets you set
everything to one region -- mine is set to "English (United States)." I
think this sets the date, decimal point, etc.. all at once.
Thats what I did, with no effect...
Try running help as soon as you open the editor, before opening any Stamp
files. This may indicate another issue as well.
Thats what I did, with no effect... :-)
Must be some more german stuff that goes wrong...
Original Message
sorry, wrong.
mistake. :-(
According to what was mentioned previously, this has to do with having the
date in Windows set to the European (day, month year) format and/or using a
comma (,) for a decimal point. Try using the US (month, day, year) format
for the date and changing the decimal point to a period (.)
Parallax is aware of this and is supposed to fix it.
Original Message
> I downloaded and installed the new windows software editor ver 1.2 on
> different computers, running Win98 and Win NT4.0.
> On both systems the Help - Contents pull down menu gives the "'4.74' is
not
> a floating point value." error.
> Does someone have any idees to correct this problem?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
