AW: AW: [basicstamps] Hardware experiment
hey doug,
I tried EVERYTHING I know including battery-power for the stamp with almost
no effect.
Urspr
no effect.
Urspr
thanks for your answer, but yes, I did try everything you suggested plus
battery-supply for the stamp with no result. Could you explain a few more
words on ground loops?
I will look at you site now, thanks again,
Uli
Urspr
I read your comments on brownout with great interest. Does the different
behaviour of the SX / e / p also make them less sensitive to noise on the
wire as well as on the 'air'? Do you have any experience about that?
Learning is the best in life. Thanks Tracy!
Uli
Urspr
Doug
On 11 Oct 2001, at 10:09, ulibasic wrote:
> hey doug,
> almost no effect.
Urspr
