AW: AW: [basicstamps] Hardware experiment — Parallax Forums
edited 2001-10-12 12:57 in General Discussion
hey doug,
I tried EVERYTHING I know including battery-power for the stamp with almost
no effect.
Urspr
    edited 2001-10-11 09:13
    Hi Tracy,
    thanks for your answer, but yes, I did try everything you suggested plus
    battery-supply for the stamp with no result. Could you explain a few more
    words on ground loops?
    I will look at you site now, thanks again,
    Uli
    Urspr
    edited 2001-10-11 09:33
    Hi Tracy,
    I read your comments on brownout with great interest. Does the different
    behaviour of the SX / e / p also make them less sensitive to noise on the
    wire as well as on the 'air'? Do you have any experience about that?
    Learning is the best in life. Thanks Tracy!
    Uli
    Urspr
    What is your application?
    Doug
    On 11 Oct 2001, at 10:09, ulibasic wrote:
    > hey doug,
    > almost no effect.
    Urspr
