Instrumentation amps
There are some precision, low-noise chips and modules designed specifically
for instrumentation amps, but I can't remember the numbers. We used
Burr-Brown modules on the oilfield stuff I used to work on.
Do a search in Yahoo for PRECISION OP-AMP and you should get quite a few web
matches.
Original Message
> If I wanted to measure pressure using several pressure sensors, then I
would need an instrumentation amp for each sensor. What would be the easiest
way to connect them to my a/d converters using the least amount of hardware?
The last one I made used several op amps which consisted of two chips and
some pots and a bunch of perfect resistors. Do they have this in an IC
package?
matches.
Original Message
package?
amps with 4 precision resistors configured to make a unity gain difference
amplifier. The resistors are 25K ( if I remember correctly ). If you need
higher input impedance or gain, try an INA121. I've had good luck with them.
>matches.
Original Message
>package?
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________
Mike Walsh
walsh@i...
need an instrumentation amp for each sensor. What would be the easiest way to
connect them to my a/d converters using the least amount of hardware? The last
one I made used several op amps which consisted of two chips and some pots and a
bunch of perfect resistors. Do they have this in an IC package?
differential FET inputs which means that you can use large input
resistors. I use them with 1 Mohm input resistors. You can also include
components for low-pass filtering at the input, as shown in the BB ap
notes. If you don't need the large input impedance of FET inputs,
Burr-Brown has a series of INA1-- chips with lower input impedance.
Dennis
On Tue, 9 Oct 2001, Mike Walsh wrote:
> I think you're looking for the Burr Brown INA105 . They are precision op
> Mike
> >matches.
Original Message
> >package?
> Mike Walsh
> walsh@i...
> from the same email address that you subscribed. Text in the Subject and Body
differential (piezo resistive bridge) type transducers. Parts count
is very low. LM11 may be hard to find, OP-07's are everywhere.
regards
rich
then I would need an instrumentation amp for each sensor. What would
be the easiest way to connect them to my a/d converters using the
least amount of hardware? The last one I made used several op amps
which consisted of two chips and some pots and a bunch of perfect
