Instrumentation amps — Parallax Forums
edited 2001-10-11 17:19 in General Discussion
There are some precision, low-noise chips and modules designed specifically
for instrumentation amps, but I can't remember the numbers. We used
Burr-Brown modules on the oilfield stuff I used to work on.
Do a search in Yahoo for PRECISION OP-AMP and you should get quite a few web
matches.
> If I wanted to measure pressure using several pressure sensors, then I
would need an instrumentation amp for each sensor. What would be the easiest
way to connect them to my a/d converters using the least amount of hardware?
The last one I made used several op amps which consisted of two chips and
some pots and a bunch of perfect resistors. Do they have this in an IC
package?
    edited 2001-10-09 17:52
    I think you're looking for the Burr Brown INA105 . They are precision op
    amps with 4 precision resistors configured to make a unity gain difference
    amplifier. The resistors are 25K ( if I remember correctly ). If you need
    higher input impedance or gain, try an INA121. I've had good luck with them.
    >matches.
    >package?
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________
    Mike Walsh
    walsh@i...
    edited 2001-10-09 17:57
    If I wanted to measure pressure using several pressure sensors, then I would
    need an instrumentation amp for each sensor. What would be the easiest way to
    connect them to my a/d converters using the least amount of hardware? The last
    one I made used several op amps which consisted of two chips and some pots and a
    bunch of perfect resistors. Do they have this in an IC package?
    edited 2001-10-09 21:08
    Added to Mike's and Rodent's suggestions is that the INA121 has
    differential FET inputs which means that you can use large input
    resistors. I use them with 1 Mohm input resistors. You can also include
    components for low-pass filtering at the input, as shown in the BB ap
    notes. If you don't need the large input impedance of FET inputs,
    Burr-Brown has a series of INA1-- chips with lower input impedance.
    Dennis
    > Mike
    > >matches.
    > >package?
    > Mike Walsh
    > walsh@i...
    A LM-11 or OP-07 are really clean op amps that work great with
    differential (piezo resistive bridge) type transducers. Parts count
    is very low. LM11 may be hard to find, OP-07's are everywhere.
    regards
    rich
    then I would need an instrumentation amp for each sensor. What would
    be the easiest way to connect them to my a/d converters using the
    least amount of hardware? The last one I made used several op amps
    which consisted of two chips and some pots and a bunch of perfect
