BS1 Starter Kit, what is that connector?
Does anyone know the part number/description for the connector that comes
with the BS1 starter kit?
There are about 20 pins on it, and I've cut them apart 3 at a time for
connecting the programming cable to my projects. I've used it all up, and
I've stolen all of the audio connectors off old sound cards that I have.
I tried to find an equivalent on Digi-Key, but they must have 10,000
different connectors.
John
John
Here's the information you requested:
BASIC Stamp Parallel Cable
#800-00001 $19
Available for purchase online:
http://www.parallaxinc.com/html_files/products/BS_Accessories/power_supply.a
sp
Erik Wood, Parallax
~~Main web site.... www.parallaxinc.com
~~Educational site.... www.stampsinclass.com
~~Spanish site at..... www.stampsenclase.com
599 Menlo Dr. Suite #100
Rocklin, CA 95765
(888) 512-1024 ph. (916) 624-8003 fax
Original Message
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9fKVrx_Q7xAYF1ZKz_10v2_OrpFy-B08tSjP4SVPnKG_yqaV5zu6ML0TkmRTH84khNGrncosWQ]john@l...[/url
Sent: Monday, October 01, 2001 8:59 AM
To: Basic Stamps
Subject: [noparse][[/noparse]basicstamps] BS1 Starter Kit, what is that connector?
John
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks for the reply, but the link was for a 12 volt power supply, and you
mentioned a parallel cable. Neither of which is what I am talking about.
I'm asking about those little pins that came with the starter kit. They
came on a 'stick' that I cut apart, 3 at a time, to solder to my project for
connecting the programming cable. As a temporary fix, I have been
scavenging audio connector pins from old CD-Rom and Sound cards... But I'm
running out fast [noparse]:)[/noparse]
Thanks again,
John
John,
#800-00001 $19
sp
Erik Wood, Parallax
Rocklin, CA 95765
Original Message
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e2wZLdWHeWfssI7N_No009Xb0itkNvC6377Osmy4gYNrY9HMtV9zrriXLTSIdo5jMu-ouWcu]john@l...[/url
To: Basic Stamps
John
supply.
Oopz.
John
Erik,
sticking out of the board, correct?
Typically you can get individual connectors on a metal strip or you can get
a segmented connector you can cut apart with the number of connections you
want. I'll have to find my Mouser catalog and see what they have.
I personally use the Molex KK connectors, and I believe the female
connectors they use will fit the pins on the Stamp boards also. You would
need to slip a piece of heat-shrink tubing over them to keep them from
touching one another though.
Original Message
for
> #800-00001 $19
each new project, not a female connector. Each new project takes 3 pins
from his stock, that's why he's running short fast
I know that Molex has this type of pins and I used them in the (remote)
past. But I do not have any reference now. Anybody having Molex catalogue
could help.
Regards, Jose Luis
At 14:38 01/10/2001 -0500, you wrote:
>Sounds like you need the little female connector that slips over the pins
Original Message
>for
> > #800-00001 $19
I should have mentioned the male/female part, Sorry.
I AM looking for the Male pins. I know this one is simple, but I'm having
trouble finding the right ones!
John
Original Message
From: Jose Luis Juarez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZMYGYZJtHabopmWv5raSaqLntL-Fw3Kohm0wi2te8x-6xD6sLMsoSdnODbElm_ZYeM5sSeSBbknT82GurA]jl.ingenieria@i...[/url
Sent: Tuesday, October 02, 2001 10:38 AM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] BS1 Starter Kit, what is that connector?
Gents, as I undestand it, our friend needs the pins (male) to solder on
could help.
Regards, Jose Luis
Close, but I need the other sex so to speak. See Jose's post nearby.
John
that's what you need, like what plugs into the BOE black female connectors?
I'd send you some taped to a letter for free if you want. Just need
address.
James R. Parish
J-Tech Internet Services
J-Com Enterprises, Inc.
Original Message
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vPyNSTRgXNh6L2kBRqqylnQ1IPw4O8p3Q3l11VxIOrhe1iP6swxsSjssCEUQ9F6CzBbJHrW75xoqoA]john@l...[/url
Sent: Tuesday, October 02, 2001 1:59 PM
Subject: RE: [noparse][[/noparse]basicstamps] BS1 Starter Kit, what is that connector?
Thank you Jose!
John
Original Message
From: Jose Luis Juarez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KmWverX8SJXAdynXE6CR2xJClJQybFMGUfEeUjri25x41x_Do094XIXFWhKS_OzGoEYu320-9T8DLqHpfYyH]jl.ingenieria@i...[/url
could help.
Regards, Jose Luis
