BS1 Starter Kit, what is that connector? — Parallax Forums
edited 2001-10-04 03:05 in General Discussion
Does anyone know the part number/description for the connector that comes
with the BS1 starter kit?
There are about 20 pins on it, and I've cut them apart 3 at a time for
connecting the programming cable to my projects. I've used it all up, and
I've stolen all of the audio connectors off old sound cards that I have.
I tried to find an equivalent on Digi-Key, but they must have 10,000
different connectors.
John
    edited 2001-10-01 17:44
    John,
    Here's the information you requested:
    BASIC Stamp Parallel Cable
    #800-00001 $19
    Available for purchase online:
    http://www.parallaxinc.com/html_files/products/BS_Accessories/power_supply.a
    sp
    Erik Wood, Parallax
    ~~Main web site.... www.parallaxinc.com
    ~~Educational site.... www.stampsinclass.com
    ~~Spanish site at..... www.stampsenclase.com
    599 Menlo Dr. Suite #100
    Rocklin, CA 95765
    (888) 512-1024 ph. (916) 624-8003 fax
    From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9fKVrx_Q7xAYF1ZKz_10v2_OrpFy-B08tSjP4SVPnKG_yqaV5zu6ML0TkmRTH84khNGrncosWQ]john@l...[/url
    Sent: Monday, October 01, 2001 8:59 AM
    To: Basic Stamps
    Subject: [noparse][[/noparse]basicstamps] BS1 Starter Kit, what is that connector?
    John
    edited 2001-10-01 20:25
    Erik,
    Thanks for the reply, but the link was for a 12 volt power supply, and you
    mentioned a parallel cable. Neither of which is what I am talking about.
    I'm asking about those little pins that came with the starter kit. They
    came on a 'stick' that I cut apart, 3 at a time, to solder to my project for
    connecting the programming cable. As a temporary fix, I have been
    scavenging audio connector pins from old CD-Rom and Sound cards... But I'm
    running out fast [noparse]:)[/noparse]
    Thanks again,
    John
    John,
    #800-00001 $19
    sp
    Erik Wood, Parallax
    Rocklin, CA 95765
    From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e2wZLdWHeWfssI7N_No009Xb0itkNvC6377Osmy4gYNrY9HMtV9zrriXLTSIdo5jMu-ouWcu]john@l...[/url
    To: Basic Stamps
    John
    edited 2001-10-01 20:34
    Correction, the link was to a bunch of accessories, not just a 12 volt power
    supply.
    Oopz.
    John
    Erik,
    edited 2001-10-01 20:38
    Sounds like you need the little female connector that slips over the pins
    sticking out of the board, correct?
    Typically you can get individual connectors on a metal strip or you can get
    a segmented connector you can cut apart with the number of connections you
    want. I'll have to find my Mouser catalog and see what they have.
    I personally use the Molex KK connectors, and I believe the female
    connectors they use will fit the pins on the Stamp boards also. You would
    need to slip a piece of heat-shrink tubing over them to keep them from
    touching one another though.
    for
    > #800-00001 $19
    edited 2001-10-02 16:37
    Gents, as I undestand it, our friend needs the pins (male) to solder on
    each new project, not a female connector. Each new project takes 3 pins
    from his stock, that's why he's running short fast
    I know that Molex has this type of pins and I used them in the (remote)
    past. But I do not have any reference now. Anybody having Molex catalogue
    could help.
    Regards, Jose Luis
    >for
    > > #800-00001 $19
    edited 2001-10-02 18:59
    Thank you Jose!
    I should have mentioned the male/female part, Sorry.
    I AM looking for the Male pins. I know this one is simple, but I'm having
    trouble finding the right ones!
    John
    From: Jose Luis Juarez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZMYGYZJtHabopmWv5raSaqLntL-Fw3Kohm0wi2te8x-6xD6sLMsoSdnODbElm_ZYeM5sSeSBbknT82GurA]jl.ingenieria@i...[/url
    Sent: Tuesday, October 02, 2001 10:38 AM
    Subject: Re: [noparse][[/noparse]basicstamps] BS1 Starter Kit, what is that connector?
    could help.
    Regards, Jose Luis
    edited 2001-10-02 19:00
    Rodent,
    Close, but I need the other sex so to speak. See Jose's post nearby.
    John
    Do you mean the .1 on center single and dual rows? I have boxes of them if
    that's what you need, like what plugs into the BOE black female connectors?
    I'd send you some taped to a letter for free if you want. Just need
    address.
    James R. Parish
    J-Tech Internet Services
    J-Com Enterprises, Inc.
    From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vPyNSTRgXNh6L2kBRqqylnQ1IPw4O8p3Q3l11VxIOrhe1iP6swxsSjssCEUQ9F6CzBbJHrW75xoqoA]john@l...[/url
    Sent: Tuesday, October 02, 2001 1:59 PM
    Subject: RE: [noparse][[/noparse]basicstamps] BS1 Starter Kit, what is that connector?
    Thank you Jose!
    John
    From: Jose Luis Juarez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KmWverX8SJXAdynXE6CR2xJClJQybFMGUfEeUjri25x41x_Do094XIXFWhKS_OzGoEYu320-9T8DLqHpfYyH]jl.ingenieria@i...[/url
    could help.
    Regards, Jose Luis
