Compact Flash Interface
Has anyone ever interfaced a Stamp to a compact flash card?
I'm building a LONG term data storage/logging device for environmental
information. The units will be to cumbersome to move and bring back to
the lab for download, so I'd like something that I can just
remove/replace (like a compact flash card) then easily download that.
Plus with all the readers out there I thought that would be a good
solution.
Any ideas?
Nathan
solution.
Any ideas?
Nathan
I've used the CF1 from www.persistor.com - they work very well, but cost
over US$500.
I'm currently looking at the Flashcore from
http://www.tern.com/flashcore.htm
Much cheaper, but haven't got my hands on any yet.
Dave
One other possibility I've investigated is using a USB root hub chip to
access a USB hard drive or key-chain style memory block. I've never
worked with USB on the hardware level so I'm still learning if it's
worth it or not.
Nathan
Original Message
From: david@b... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=w0_r-oxUvsSpjZsW7fHptNshVvGoepNAVaBvad_zOtQ9LMmYyLCiM9BfdnQz70XdPd6kCo5MfUY]david@b...[/url
Sent: Sunday, August 26, 2001 5:14 AM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Compact Flash Interface
On 25 Aug 01, at 13:23, Nathan Brown <basicstamps@yahoogroups.com>
over US$500.
Dave
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
You might look at MMC cards which have a serial type interface in addition
to the CF interface.
Here is one interfaced to a PIC.
http://www.compsys1.com/workbench/On_top_of_the_Bench/MMC_Project/
mmc_project.html
Some obstacles; requires 3.3v interface and 512 byte block writes.
addition to the CF interface.
Whoops, I thought they had both interfaces, but they are just serial
(MMC or SPI). There are adapters to put them in PCCARD slots ala CF
cards.
