Erasing eeprom
Ricky-
Depends. If the variable "loop" is a byte variable, it will only
erase 0 to 255 (since a byte variable's value cannot exceed 255).
If it's a word variable, it ought to clear 0 to 482.
Steve
Steve
For loop 0 to 482
write loop,0
pause 10
next
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, July 13, 2001 2:37 PM
Subject: [noparse][[/noparse]basicstamps] Erasing eeprom
> Should this code erase, or set to zero, memory locations 0 to 482 on a
bs2p?
> For loop 0 to 482
> write loop,0
> pause 10
> next
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>bs2p?
> > For loop = 0 to 482
> > write loop,0
> > pause 10
> > next
Ricky,
Yes, that should work fine, if by "erase" you mean set all of those
bytes to zero. Sometimes $ff is used for the "erased" state.
This works in the current bank. To erase data in a different bank,
preface the routine with the STORE n command, where n is 0 to 7 for
the bank number.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
Are you making a general statement or speaking of the
Stamp in particular? As a C++ guy by training, I
understand the importance of not assuming that a
declared variable will start at 0 without formal
assignment, but I am very dependent on the assumption
that virgin Stamp EEPROM is 0.
Bob Pence
> >bs2p?
> > > For loop = 0 to 482
> > > write loop,0
> > > pause 10
> > > next
> Ricky,
> set all of those
> "erased" state.
> different bank,
> n is 0 to 7 for
> the bank number.
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail
http://personal.mail.yahoo.com/
richard
Original Message
Sent: Saturday, July 14, 2001 12:09 PM
Subject: Re: [noparse][[/noparse]basicstamps] Erasing eeprom
> Tracy -
> Bob Pence
> > >bs2p?
> > > > For loop = 0 to 482
> > > > write loop,0
> > > > pause 10
> > > > next
> > Ricky,
> > set all of those
> > "erased" state.
> > different bank,
> > n is 0 to 7 for
> > the bank number.
> > -- regards,
> > Tracy Allen
> > mailto:tracy@e...
> > ignored.
> Do You Yahoo!?
can be the cleared/erased state. To write to the typical Flash Memory
device, it is first "erased" to read all '1's, next any bit that is
supposed to be a '0', is cleared.
If you wanted to erase a Flash device, it would wear a device less, if you
erased it to all '1's. Not up to speed on EEPROM implementation. That
class was way too long ago.
Joshua
--On Saturday, July 14, 2001 1:15 PM -0500 Richard Friedrich
<rfriedrich@a...> wrote:
> wouldnt it take only 3 or 4 lines of code to write a zero to all
> locations ?
> richard
Original Message
> From: "Pence Bob" <bobpence_2000@y...>
>> Tracy -
>> Bob Pence
>> > > bs2p?
>> > > > For loop = 0 to 482
>> > > > write loop,0
>> > > > pause 10
>> > > > next
>> > Ricky,
>> > set all of those
>> > "erased" state.
>> > different bank,
>> > n is 0 to 7 for
>> > the bank number.
>> > -- regards,
>> > Tracy Allen
>> > mailto:tracy@e...
>> > ignored.
>> Do You Yahoo!?
