Erasing eeprom — Parallax Forums
Erasing eeprom
edited 2001-07-15 06:34 in General Discussion
Ricky-
Depends. If the variable "loop" is a byte variable, it will only
erase 0 to 255 (since a byte variable's value cannot exceed 255).
If it's a word variable, it ought to clear 0 to 482.
Steve
    edited 2001-07-13 20:37
    Should this code erase, or set to zero, memory locations 0 to 482 on a bs2p?
    For loop 0 to 482
    write loop,0
    pause 10
    next
    edited 2001-07-13 20:43
    loop = I mean
    Sent: Friday, July 13, 2001 2:37 PM
    Subject: [noparse][[/noparse]basicstamps] Erasing eeprom
    bs2p?
    > For loop 0 to 482
    > write loop,0
    > pause 10
    > next
    edited 2001-07-14 03:26
    >bs2p?
    > > For loop = 0 to 482
    > > write loop,0
    > > pause 10
    > > next
    Ricky,
    Yes, that should work fine, if by "erase" you mean set all of those
    bytes to zero. Sometimes $ff is used for the "erased" state.
    This works in the current bank. To erase data in a different bank,
    preface the routine with the STORE n command, where n is 0 to 7 for
    the bank number.
    -- regards,
    Tracy Allen
    mailto:tracy@e...
    http://www.emesystems.com
    edited 2001-07-14 18:09
    Tracy -
    Are you making a general statement or speaking of the
    Stamp in particular? As a C++ guy by training, I
    understand the importance of not assuming that a
    declared variable will start at 0 without formal
    assignment, but I am very dependent on the assumption
    that virgin Stamp EEPROM is 0.
    Bob Pence
    > >bs2p?
    > > > For loop = 0 to 482
    > > > write loop,0
    > > > pause 10
    > > > next
    > Ricky,
    > set all of those
    > "erased" state.
    > different bank,
    > n is 0 to 7 for
    > the bank number.
    > -- regards,
    > Tracy Allen
    > mailto:tracy@e...
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________________________
    Do You Yahoo!?
    Get personalized email addresses from Yahoo! Mail
    http://personal.mail.yahoo.com/
    edited 2001-07-14 19:15
    wouldnt it take only 3 or 4 lines of code to write a zero to all locations ?
    richard
    Sent: Saturday, July 14, 2001 12:09 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Erasing eeprom
    > Tracy -
    > Bob Pence
    > > >bs2p?
    > > > > For loop = 0 to 482
    > > > > write loop,0
    > > > > pause 10
    > > > > next
    > > Ricky,
    > > set all of those
    > > "erased" state.
    > > different bank,
    > > n is 0 to 7 for
    > > the bank number.
    > > -- regards,
    > > Tracy Allen
    > > mailto:tracy@e...
    > > ignored.
    > Do You Yahoo!?
    Here's another point of view. Depending on the memory technology, a '1'
    can be the cleared/erased state. To write to the typical Flash Memory
    device, it is first "erased" to read all '1's, next any bit that is
    supposed to be a '0', is cleared.
    If you wanted to erase a Flash device, it would wear a device less, if you
    erased it to all '1's. Not up to speed on EEPROM implementation. That
    class was way too long ago.
    Joshua
    --On Saturday, July 14, 2001 1:15 PM -0500 Richard Friedrich
    > locations ?
    > richard
    > From: "Pence Bob" <bobpence_2000@y...>
    >> Tracy -
    >> Bob Pence
    >> > > bs2p?
    >> > > > For loop = 0 to 482
    >> > > > write loop,0
    >> > > > pause 10
    >> > > > next
    >> > Ricky,
    >> > set all of those
    >> > "erased" state.
    >> > different bank,
    >> > n is 0 to 7 for
    >> > the bank number.
    >> > -- regards,
    >> > Tracy Allen
    >> > mailto:tracy@e...
    >> > ignored.
    >> Do You Yahoo!?
