potentiometer life
I was reading the Bourns data in Digi-key about cycle of a
potentiometer.
I want to use pot to measure the postion of a shaft, only 90
degreees.
The data said 200 cycles (4%Delta TR)
does anybody have expericance with number or turns a pot can handle
before failing or being way off?
I was planing on only a few miliamps throught it so power should not
be a problem.
TIA
Dave
potentiometer.
degreees.
be a problem.
TIA
Dave
Model RC (cars, boats, airplanes, etc.) devices use a potentiometer with
out fail for many cycles, for the feedback mechanism. Often times I've
seen a micro switch and a cam used for damper position feed back.
Usually not more than 4 absolute positions are important anyway i.e.
open -- closed -- 45 degrees and maybe one other position. Just an
idea !!
Leroy
> potentiometer.
> degreees.
> be a problem.
> TIA
> Dave
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
* LeRoy Hall, Senior N8VRC, CET *
* Phase converters 2hp to 25hp for sale guaranteed *
* to run your motor. $250 for small 2 hp unit. *
* Micro one PLCS for Sale. 8 DC inputs six relay *
* outputs $49.95 Software included... *
* Please see for complete details: *
* http://www.idec.com/usa/html/PLCs_MICRO1.html *
* Phone: (513) 697-7539 *
* Cell : (513) 300-8632 *
* Email: leroy@f... *
* Home page URL: http://home.fuse.net/leroy/ *
* Resume URL: http://home.fuse.net/leroy/resume.htm *
* Leroy Hall *
* 317 Cherokee Drive *
* Loveland, Ohio - USA 45140-2404 *
Consider using a single turn cermet pot as a servo pot. These devices
typically have 10 million revolution lifetimes.
http://www.spectrol.com/pdfs/357.pdf Linearity is about 2%. You can get
better grade "servo pots" from many manufacturers, but most applications
won't need anything more than these pots offer. I have several of this
vintage in installations that are 20+ years old and running fine.
>potentiometer.
>degreees.
>be a problem.
>TIA
>Dave
_________________________________
Mike Walsh
walsh@i...
