potentiometer life — Parallax Forums
potentiometer life
edited 2001-05-09 00:14 in General Discussion
I was reading the Bourns data in Digi-key about cycle of a
potentiometer.
I want to use pot to measure the postion of a shaft, only 90
degreees.
The data said 200 cycles (4%Delta TR)
does anybody have expericance with number or turns a pot can handle
before failing or being way off?
I was planing on only a few miliamps throught it so power should not
be a problem.
TIA
Dave
    edited 2001-05-08 22:25
    AN optical device would be preferred. how ever they are more expensive.
    Model RC (cars, boats, airplanes, etc.) devices use a potentiometer with
    out fail for many cycles, for the feedback mechanism. Often times I've
    seen a micro switch and a cam used for damper position feed back.
    Usually not more than 4 absolute positions are important anyway i.e.
    open -- closed -- 45 degrees and maybe one other position. Just an
    idea !!
    Leroy
    > potentiometer.
    > degreees.
    > be a problem.
    > TIA
    > Dave
    * LeRoy Hall, Senior N8VRC, CET *
    * Phase converters 2hp to 25hp for sale guaranteed *
    * to run your motor. $250 for small 2 hp unit. *
    * Micro one PLCS for Sale. 8 DC inputs six relay *
    * outputs $49.95 Software included... *
    * Please see for complete details: *
    * http://www.idec.com/usa/html/PLCs_MICRO1.html *
    * Phone: (513) 697-7539 *
    * Cell : (513) 300-8632 *
    * Email: leroy@f... *
    * Home page URL: http://home.fuse.net/leroy/ *
    * Resume URL: http://home.fuse.net/leroy/resume.htm *
    * Leroy Hall *
    * 317 Cherokee Drive *
    * Loveland, Ohio - USA 45140-2404 *
    Dave,
    Consider using a single turn cermet pot as a servo pot. These devices
    typically have 10 million revolution lifetimes.
    http://www.spectrol.com/pdfs/357.pdf Linearity is about 2%. You can get
    better grade "servo pots" from many manufacturers, but most applications
    won't need anything more than these pots offer. I have several of this
    vintage in installations that are 20+ years old and running fine.
    >potentiometer.
    >degreees.
    >be a problem.
    >TIA
    >Dave
    _________________________________
    Mike Walsh
    walsh@i...
