BS2 homemade board serial comm. prob.
I'm building a small little 'bot. I've put a BS2 on a proto board. I've also
wired up a programming cable. When I try to program it I get a comm error
that says that the BS2 is detected but I should check the power supply. I've
hooked the board up to the power supply on the BOE. The BS2 works find in
the BOE. My power supply looks fine. There is ~4.97v (same as BOE) on PWR &
+5V. I'm powering it from a regulated 5v. Like the BOE. Suggestions?
-William
http://www.GoRobotics.net
Robotics projects, links,
resources, news, and more!
Are you 100% sure ...
That if you died tonight,
you'd go to heaven?
Why have doubts??
-William
you'd go to heaven?
Why have doubts??
external source, the other is for 9-12 volts, which is then regulated on the
BS2 module. On the BOE, the regulator on the board supplies the power. On
the Activity Board, the chip itself regulates the power. You use one or the
other, depending on what your power requirements are for external devices,
etc... If you are supplying 5 volts to the 9-12 volt input on the BS2, the
input voltage is too low for the regulator to do its job.
Look at the BOE schematic on the Parallax web site and see which pin is
connected to the regulator on the BOE.
Original Message
also
I've
loopback) to COM1 but tell stampw.exe to not use COM1 (which I know
to be the correct serial port to access the Stamp), I get the
following message when trying to run a program:
"BASIC Stamp II detected but not responding on COM3!
Check power supply."
Conclusion: the editor can make a mistake by detecting a Stamp where
there is none (in this case, on COM3) and giving a misleading error
message as a result. Make sure the editor is trying to access your
Stamp from the correct serial port. If you don't know for sure which
serial port you ought to specify, try forcing COM1, then COM2 etc.
Why can you successfully program your Stamp on the BOE but not on
your board? My guess is your cable doesn't have the RTS-->DSR
loopback so the editor is not finding your Stamp's serial port
automatically. The BOE may have this loopback on the PCB itself
(anybody know for sure?) so a garden variety cable works fine on it.
Steve
> I've also wired up a programming cable. When I try to program it I
> get a comm error that says that the BS2 is detected but I should
> check the power supply. I've hooked the board up to the power supply
> on the BOE. The BS2 works find in the BOE. My power supply looks
> -William
> you'd go to heaven?
> Why have doubts??
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
unregulated pin. The chip *runs* fine in my board. It just won't DL.
-William
you'd go to heaven?
Why have doubts??
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, April 21, 2001 5:36 AM
Subject: [noparse][[/noparse]basicstamps] Digest Number 609
> There are 14 messages in this issue.
> Topics in this digest:
> 1. Re: Digest Number 608 unsubscribe
> From: "Paul Gatcum" <pgatcum@n...>
> 2. RE: unsubscribe
> From: "Michael Clark" <mdc@i...>
> 3. Re: multiple LTC1298
> From: bs2web@y...
> 4. Re: Freelance Programmers : Some clarifications
> From: iceninevt@y...
> 5. bs2 wave/mp3 file retrieval for project?
> From: jhtoolman2000@y...
> 6. Re: bs2 wave/mp3 file retrieval for project?
> From: Bruce Bates <bvbates@u...>
> 7. Re: bs2 wave/mp3 file retrieval for project?
> From: jonwms@a...
> 8. Re: bs2 wave/mp3 file retrieval for project?
> From: "S Parkis" <parkiss@e...>
> 9. GPS variables
> From: mdmontoya22@y...
> 10. Re: GPS variables
> From: Rodent <daweasel@s...>
> 11. Re: GPS variables
> From: Matthew K <m_klarich@y...>
> 12. BS2 homemade board serial comm. prob.
> From: "William Cox" <william@c...>
> 13. Re: BS2 homemade board serial comm. prob.
> 14. Re: BSI Problems
> From: ARTICALEX@A...
> ________________________________________________________________________
> Message: 1
> Date: Fri, 20 Apr 2001 19:52:20 +1000
> Subject: Re: Digest Number 608 unsubscribe
> Unsubscribe this is a very dificult list to get out of.
Original Message
> From: <basicstamps@yahoogroups.com>
> Sent: Friday, April 20, 2001 7:16 PM
> Subject: [noparse][[/noparse]basicstamps] Digest Number 608
> > There are 20 messages in this issue.
> > 1. Re: Floppy Drive
> > From: davemucha@j...
> > 2. Re: 6502 Help
> > From: burtsz@a...
> > 3. Power up required ?
> > From: avi bhagtani <ronals22@y...>
> > 4. Re: happy birthday code
> > From: "Nicolas Fournel" <Nicolas.Fournel@f...>
> > 5. Checking time
> > From: "L .Gaminde" <lgaminde@t...>
> > 6. Re: Checking time
> > 7. RE: Checking time
> > From: "D. Daniel McGlothin" <ddm@r...>
> > 8. multiple LTC1298
> > From: electronguy@a...
> > 9. Re: Checking time
> > 10. BSI Laptop Circuit
> > From: theryan@t...
> > 11. Basic Stamp Emulator
> > From: david cousins <cuz_hsv@y...>
> > 12. RE: Freelance Programmers : Some clarifications
> > From: "Nagi Babu" <nags@c...>
> > 13. Re: Checking time
> > From: Tracy Allen <tracy@e...>
> > 14. RE: boebot IR sensors
> > 15. Re: Checking time
> > 16. Re: Stepper motor
> > From: Roger Edberg <postmaster@i...>
> > 17. Re: multiple LTC1298
> > From: Mike Hardwick <decade@w...>
> > 18. sounds
> > From: "Pieter-Jan van Diepen" <diepenpj@h...>
> > 19. Re: Checking time
> > 20. Re: multiple LTC1298
> > Message: 1
> > Date: Thu, 19 Apr 2001 12:50:32 -0000
> > Subject: Re: Floppy Drive
> > Search this forum.
> > there was a link a few months ago of a gentleman
> > who was getting floppy drives with the interface
> > so it could be used with the Stamp.
> > and if you find good information, please let us know.
> > Dave
> > --- In basicstamps@au.egroups.com, Alejandro Vazquez
> > <alexvazquez@y...> wrote:
> > > Hello,,
> > > I would like to interface the basic stamp to a floppy
> > > disk drive 3 1/2".
> > > If anyone knows how to do this please let me know!!
> > > Regards,
> > > Alejandro Vazquez
> > > Do You Yahoo!?
> > > Get email at your own domain with Yahoo! Mail.
> > > http://personal.mail.yahoo.com/
> > Message: 2
> > Date: Thu, 19 Apr 2001 10:31:01 EDT
> > From: burtsz@a...
> > Subject: Re: 6502 Help
> > Hi ECO, The 6800 was born prior to the 6502 and was introduced to the
> world
> > about mid-1974. One of the members of the 6800 design team at Motorola
> > (based in Phoenix, AZ) jumped ship after the 6800 was designed and
joined
> MOS
> > Technology where he (and others) designed the 6502. The 6502 is very
> similar
> > to the 6800 architecture and instruction set and found it's fame and
> fortune
> > in the first Apple computer. Both are much easier to use (both hardware
> and
> > software) than the Intel family, 8008, 8080, etc. FYI, Burt Schultz
> > Message: 3
> > Date: Thu, 19 Apr 2001 08:11:54 -0700 (PDT)
> > Subject: Power up required ?
> > if I plug in an additional basic stamp chip to the
> > basic stamp board of education do i need another power
> > supply . or the 9 V adapter already plugged into the
> > board is enough ? i am like working on connecting
> > these two chips in series .
> > thankz
> > avi
> > Do You Yahoo!?
> > Yahoo! Auctions - buy the things you want at great prices
> > http://auctions.yahoo.com/
> > Message: 4
> > Date: Thu, 19 Apr 2001 10:28:47 -0700
> > Subject: Re: happy birthday code
> > Thanks a lot. It will save me a lot of time !
> > Nicolas
> > >>> "Sean T. Lamont .lost." <lamont@a...> 04/18/01 04:43PM
> > It's very easy to generate. Each half step is 1.05946 times the previous
> > half step, since frequency is a log scale. So
> > A = Frequency 440.00
> > A# = Frequency 466.16
> > B = Frequency 493.88
> > C = Frequency 523.25
> > C# = Frequency 554.37
> > D = Frequency 587.33
> > D# = Frequency 622.25
> > E = Frequency 659.26
> > F = Frequency 698.46
> > F# = Frequency 739.99
> > G = Frequency 783.99
> > G# = Frequency 830.61
> > A = Frequency 880.00
> > A# = Frequency 932.33
> > B = Frequency 987.77
> > C = Frequency 1046.50
> > C# = Frequency 1108.73
> > D = Frequency 1174.66
> > D# = Frequency 1244.51
> > E = Frequency 1318.51
> > F = Frequency 1396.91
> > F# = Frequency 1479.98
> > G = Frequency 1567.98
> > G# = Frequency 1661.22
> > A = Frequency 1760.00
> > FYI, the factor 1.059 is based on a logarithmic scale which doubles
every
> > octave. Thus it's the twelfth root (over twelve logarithmic steps) of
> > doubling, or root 12 of two.
> > In answer to the original question, happy birthday to you
> > G G A G C B
> > G G A G D C
> > G G G E C B A
> > F F E C D C
> > You'll have to work out which octaves I'm talking about.
> > As a final note, here's some C code that generates this table.
> > #include<math.h>
> > main()
> > int i;double freq,factor;
> > freq = 440.0;
> > for (i=0;i<25;++i){
> > factor = pow(2.0,(1.0/12.0));
> > freq = freq * factor;
> > printf("Frequency %0.2lf\n",freq);
> > On Wed, 18 Apr 2001, david cousins wrote:
> > > Nicolas,
> > > Did anyone help you yet? I tried looking up the chart of musical
notes
> for the
> > > stamp, but couldn't find it. I know I saw it in there somewhere. All
I
> found
> > > yesterday was the Morris Code chart.
> > > Dave
> > > --- Nicolas Fournel <Nicolas.Fournel@f...> wrote:
> > > > Hi,
> > > > Does anybody know where to find the code to play the happy birthday
> theme
> > > > using freqout?
> > > > Nicolas
> > > Do You Yahoo!?
> > Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
> > Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma -
Bremerton
> > email: lamont@a... WWW: http://www.serv.net
> > "...There's no moral, it's just a lot of stuff that happens". - H.
Simpson
> > Message: 5
> > Date: Thu, 19 Apr 2001 11:21:16 -0700
> > Subject: Checking time
> > Im using a DS1302 RTC I have a program that does a number of things, I
> have
> > one function that I need to do on an interval of 30 min or greater. In
> > writing code to check the clock I find that I have a page of if then
> > statements.
> > I will need to check the minutes if the minutes are less than the last
> > saved minutes,
> > I will need to check the hours, if the hours are less than the last
saved
> > hours then
> > I will need to check the days if the days are less than the saved day
then
> > I will need to check the months if the month is less than the last saved
> > month
> > I will need to check the year
> > Does anyone have a quick and dirty way of doing this without using so
many
> > if then statements is there a way of adding all the values up
> > and subtracting one time ?? something like below and also in a smaller
> > size to fit the stamps 65535 limit
> > old value
> > min = 12
> > hour = 24
> > day = 6
> > month = 11
> > year = 01
> > old value = 0111062412
> > new value
> > min = 04
> > hour = 23
> > day = 8
> > month = 11
> > year = 01
> > new value = 0111082304
> > Message: 6
> > Date: Thu, 19 Apr 2001 11:42:23 -0700
> > Subject: Re: Checking time
> > maybe something like this Is this a good way of thinking or not
> > year month\day hour\min
> > new date 01 1108 2304
> > last saved date 01 1106 2412
____________________________________________________________________________
> _____
> > subtract 00 0002 -108
> > so what would be the next step
> have
> > > statements.
> > > saved minutes,
> saved
> > > hours then
> then
saved
> > > month
> many
smaller
> > > old value
> > > min = 12
> > > hour = 24
> > > day = 6
> > > month = 11
> > > year = 01
> > > new value
> > > min = 04
> > > hour = 23
> > > day = 8
> > > month = 11
> > > year = 01
> > Message: 7
> > Date: Thu, 19 Apr 2001 14:56:42 -0400
> > Subject: RE: Checking time
> > Assuming that you need to do the function on a regular interval of any
> > minutes between 1 and 59 minutes, you could ignore all the other pieces
of
> > the date-time and focus on the minutes byte only. For example,
> > if oldMM > newMM
> > then diffMM = newMM + 60 - oldMM
> > else diffMM = newMM - oldMM
> > endif
> > if diffMM > intervalMM
> > then do function
> > endif
> > Basically, the pseudocode checks if the minutes register experienced a
> > wrap-around since the last time check, and calculates the difference
> between
> > the old time and time new time.
> > This technique requires that the interval AND the checks for the
interval
> > expiring be less than 60 minutes long. Also note that the resolution of
> > this method will never be less than 1 minute.
> > Regards,
> > Daniel McGlothin
Original Message
> > From: L .Gaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AKCCxPnbFeULmv4KnVWeTwpdgEBde_GUd7WJpAsNhYPdPI_pfkCLjTZm8-iBlAJQcnNz6O7Jrt47aTwIeg]lgaminde@t...[/url
> > Sent: Thursday, April 19, 2001 2:42 PM
> > To: basicstamps@yahoogroups.com
> > Subject: Re: [noparse][[/noparse]basicstamps] Checking time
> > _____
> > have
> > > statements.
> > > saved minutes,
> saved
> > > hours then
> then
saved
> > > month
> many
smaller
> > > old value
> > > min = 12
> > > hour = 24
> > > day = 6
> > > month = 11
> > > year = 01
> > > new value
> > > min = 04
> > > hour = 23
> > > day = 8
> > > month = 11
> > > year = 01
> > Message: 8
> > Date: Thu, 19 Apr 2001 15:20:50 EDT
> > Subject: multiple LTC1298
> > Hi everyone,
> > I would like to use multiple LTC1298 ADC's with one BS2. I am thinking I
> only
> > would need one additional line for each extra ADC I add. Is there any
> > problems with doing something like this? I want to use two right now,
but
> > will eventualy have 3. I am not so hot with code for adding devices,
> mostly I
> > use code snippets I find and start working my way thru them. Any info or
> > insights would be most appreciated.
> > Thanx,
> > [noparse][[/noparse]This message contained attachments]
> > Message: 9
> > Date: Thu, 19 Apr 2001 12:42:40 -0700
> > Daniel not sure if this would work, it would be 30 minutes or greater,
so
> > the next time could be the next day or one month from the last sense,
not
> > likely but possible, Im trying to think of the worst case. Now I could
do
> > this for all the values start with year,month,day,hour,min. If I would
do
> > it like I had it laid out in year, month\day, and hour\min, I would take
> > the 0002 value and multiply by 24 for hours times 100 plus the 2304
> > hours\minutes then subtract the 2412 hours \ minutes of the last saved
> date
> > Im really not sure if im on tract here of If im going to see some major
> > screw up later in the coding. like below to keep carry over the month to
> > days I will need to know the number of days in each month, am I making
> this
> > harder than it really is ????
> > something like this
> > last saved time 24:59 12-31-01
> > new time read 01:01 01-01-02
pieces
> of
> > > if oldMM > newMM
> > > endif
> > > then do function
> > > endif
> between
> interval
of
> > > Regards,
> > > Daniel McGlothin
Original Message
> > > year month\day
hour\min
> > > _____
I
> > > have
In
> > > > statements.
last
> > > > saved minutes,
> saved
> > > > hours then
day
> then
> saved
> > > > month
so
> many
> smaller
> > > > old value
> > > > min = 12
> > > > hour = 24
> > > > day = 6
> > > > month = 11
> > > > year = 01
> > > > new value
> > > > min = 04
> > > > hour = 23
> > > > day = 8
> > > > month = 11
> > > > year = 01
> > Message: 10
> > Date: Thu, 19 Apr 2001 20:02:01 -0000
> > From: theryan@t...
> > Subject: BSI Laptop Circuit
> > I have read in a couple of places that there is a circuit you can build
> > to fix the problem between the BSI and some newer laptops. Does anyone
> > know wher I can get a hold of that? I sent an e-mail to parallax but
> > I'm still waiting for a reply. Thankyou.
> > -Ryan
> > Message: 11
> > Date: Thu, 19 Apr 2001 13:56:49 -0700 (PDT)
> > Subject: Basic Stamp Emulator
> > Hi,
> > I'm trying to introduce a friend to the Basic Stamp, and he has asked,
do
> you
> > have an emulator for the BS2?
> > I can't remember it being discussed. Anyone know?
> > Dave
> > Do You Yahoo!?
> > Message: 12
> > Date: Thu, 19 Apr 2001 17:04:06 -0500
> > Subject: RE: Freelance Programmers : Some clarifications
> > Hey Bharat Thakkar fella,
> > You need better people, why don;t you hire a head-hunter and ask them to
> > find better people? They can reach larger circle than you'd. When you
> > say, "use my logics". You must be kidding. Source code is the most
> > easily acquirable asset in this internet world we are living in. Have
> > you not heard of the concepts of "Open Source". When you build
> > something, it is bound to be used. For that matter, what makes you think
> > you OWN all of that source code that you are (supposedly) willing to
> > convert. You are crapping aren't you? That large amt of source code AND,
> > is definitely NOT YOURS in all.
> > So, please give us a break.
> > Just because, you subscribe to egroups, does not by itself mean that you
> > are NOT a spammer. It is the respect you give to the context of that
> > egroup that either makes or unmakes you a spammer.
> > Most importantly, in this world of economy, you are asking for a
> > deposit. And, you are giving some stupid reasoning for that. You expect
> > people to buy that story. Are you out of your knickers man?!! Well, why
> > don't you give me some deposit and I'll sit *** in a space shuttle and
> > take you to the moon!! Sounds like a good deal for a $100 - don'it ?!!
> > And, I'm from India too. I don't recall computers being so popular in
> > India during 1979. It started budding in the 84's. Your experience must
> > be a Smile story too. And, don't disgrace our country. Fly a kite
> > instead. I'm really getting cheesed off, especially now, because you had
> > mentioned that you are from India and pulling such a stunt. We work hard
> > to attain a good name here in the US, and people like you feed that to
> > the roaches by a stunt like this.
> > I really don't think you understand anything about anything than
> > anybody. Frankly, You must've really rented out your brains out to
> > somebody man!!
> > P.S:
> > Dear Members of basicstamp eGroups, I'm sorry for my open language in
> > this conversation. I had to speak out. I must apologize if this had
> > caused any discomfort.
> > ...Now let's build some BS-II projects
> > [noparse]:)[/noparse]
Original Message
> > From: Innovative International Institute
> > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TjXA4dSA4VlEM4L4l9i4JtSREeVz461InWi3REP8_XIzaAckcElRno3vi4HSyKT90UOLYIrvJHKkwLi5lQmUvsfQVIYzTVnWpCwbMniSQA]innovativeinstitute@s...[/url
> > Sent: Wednesday, April 18, 2001 12:44 PM
> > To: elliot@u...; perl-beginner@yahoogroups.com;
> > basicstamps@yahoogroups.com; bschwabe@a...;
> > comdeveloper@yahoogroups.com; dohays@a...;
> > ACEWAREZ@yahoogroups.com; theresaradke@c...;
> > COLOS_Linux@yahoogroups.com; dave@q...
> > Cc: damon@d...; chilton@t...; typon@a...;
> > batchell@i...; nbajammer@r...; tunatunup2000@y...;
> > sknutson@l...; fresher_papers@yahoogroups.com
> > Subject: [noparse][[/noparse]basicstamps] Freelance Programmers : Some clarifications
> > (A) : Some says why we had asked for some deposits....
> > I had pained a lot to develop a large bunch of source code in various
> > languages on various platforms like BASIC, FORTH, LOGO etc. on ATARI,
> > Commodore, Comex, ZXSpectrum, Aplle, PC and such other systems of early
> > 80s to latest Oracle, JDBC, VB, JAVA, XML etc.. I am working in the
> > field since 1979...
> > I know what is the value of source code and so I need some deposit to..
> > (a) to weed out real workers and (b) If somebody uses my logics at their
> > level at least I get something out of it (and I know most of the persons
> > will use it)
> > (B) : What is spam I know it very well...
> > Another important thing is I want to convert my source code in various
> > languages and platforms within 60 days period (and if earlier the
> > better), which is possible only this way...
> > We are in cyber culture and we must forget all old type of culture that
> > large or small companies should do that and should not do this. We must
> > go there where we find the real workers...
> > We do not want to invest wrongly in infrastructre and then kick out
> > employees when we do not need. (like at present more than 50000
> > softwares professional are kicked out by large companies in US alone...
> > why ?? I am giving work to my fellow professionals and safegurading my
> > interests, what is the wrong in it...???)
> > Who are these so called anti-spammers and well-wishers ????
> > Most of these well-wishers are great official of great companies who
> > easly kick-out there employees and put them into no-where situation..
> > Why ??? 'cause these well-wishers are in financial crunch...
> > Can they show me a single case in which I hadn't paid any of my
> > programmers... ???
> > Another thing I am not spamming 'cause we are subscribers of same
> > egroups...
> > Somebody had jammed my emails.... That is not good... That is not
> > democracy...
> > (C) : Some says I am using free emails...
> > I have connections from 4 local ISPs at my home and office... and I had
> > paid for it... as some free email services giving more space and better
> > services we use them ... what is the wrong in it ???? I do not
> > understand...
> > Using different emails for different purposes we can manage our
> > work-force in a proper way... that is our aim...
> > (D) : I am since 1979 in the field. --- what is source-code --- what is
> > internet --- what is spam, I understand better than any other....
> > Before putting this project in work I had done a good brain-storming
> > work...
> > (E) : I need better people that is all...
> > Bharat Thakkar
> > F/3, Ten Bungalows,
> > Polytechnic
> > Ahmedabad - 380 015
> > India
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > <http://docs.yahoo.com/info/terms/> Service.
> > Message: 13
> > Date: Thu, 19 Apr 2001 15:00:55 -0700
> have
> > >statements.
> > Hi Larry,
> > I like to make a conversion to Julian date/time in the subroutine
> > that reads the real time clock. That gives a single monotonically
> > increasing number to deal with in the rest of the program. The
> > action at intervals is then simply a question of divisibility.
> > if timenumber//interval=0 then its_time_now
> > In data loggers, I am using intervals that can range from 1 minute to
> > 6 hours, so I use the code:
> > julian1 = hour*60+minute
> > where hour is from 0 to 23 and minute is from 0-59, so Julian goes
> > from 0 to 1439, from midnight to 11:59pm (Be sure to use standard
> > values in the calculation, not bcd coded values.) Then you have a
> > choice of a lot of intervals that divide 1440 evenly:
> > 1,2,3,4,5,6,10,15,20,,30,60,120,180,240,360 minutes and some others.
> > Then:
> > if julian10//30=0 then do30minutestuff
> > If you need seconds, you can get down to 2 second intervals, and
> > still fit it into one 16 bit word. (43200 2-second intervals in a
> > day) 10 minute intervals will carry you for a year in one 16 bit
> > word. (52560 10 minute intervals in a leap year).
> > A BASIC Stamp formula for day of year (0 to 364 or 365) given YY
> > (year) MM (month) and DD (day) is:
> > JD=MM-1*30+(MM/9+MM/2)-(MM max 3/3*(YY//4 max 1 +1))+ DD
> > For explanation see,
> > http://www.emesys.com/BS2math4.htm#JulianDate
> > Then to resolve to 10 minute intervals, take the above JD value and
> > roll in the time:
> > julian10 = (JD * 144) + (hour*6) + (minute/10)
> > This julian10 value should be updated every time the program reads
> > the clock, and it has a new value for every 10 minutes in the current
> > year.
> > If you need to set an alarm for a specific time in the future, run
> > the future date/time through the above formula to get one number,
> > then check for equality.
> > if alarm=julian10 then doAlarm
> > I hope that helps,
> > -- best regards
> > Thomas Tracy Allen PhD
> > electronically monitored ecosystems
> > http://www.emesystems.com
> > mailto:tracy@e...
> > Message: 14
> > Date: Thu, 19 Apr 2001 17:08:18 -0500
> > Subject: RE: boebot IR sensors
> > Our buddy Bruce (www.rentron.com) sells those too -if I'm not mistaken.
Original Message
> > From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rVJZVfnDK8yPvTBRjAPZgUH2gprdLA_3mV4-Xh9AKhs2Kea9VvRMBoZYa369_Gx9tAFQ8aOoakA_v88]admin@m...[/url
> > Sent: Wednesday, April 18, 2001 2:25 PM
> > Subject: [noparse][[/noparse]basicstamps] boebot IR sensors
> > HI all: I see on the BoeBot, Parallax uses small IR sensors, about the
> > size
> > of an LED.
> > Where are these small sensors sold? I cannot use the larger tincan style
> > IR
> > sensor for my application.
> > Sincerely
> > Kerry
> > Admin@M...
> > WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
> > Kerry Barlow
> > p.o. box 21
> > kirkwood ny
> > 13795
> > Message: 15
> > Date: Thu, 19 Apr 2001 15:46:32 -0700
> > Tracy ! thank you, I was hoping you would come up with something, Now I
> > will look this all over for a few days ( few meaning anything from 10 to
> > 300 Julian days ) and probably have some more questions.
> > thanks again
> > Larry Gaminde
I
> have
In
> > > >statements.
> > > Hi Larry,
> > > Then:
> > > roll in the time:
> > > year.
> > > I hope that helps,
> > > -- best regards
> > > mailto:tracy@e...
> > Message: 16
> > Date: Thu, 19 Apr 2001 17:01:21 -0700
> > Subject: Re: Stepper motor
> > [noparse][[/noparse]This message is not in displayable format]
> > Message: 17
> > Date: Thu, 19 Apr 2001 18:33:57 -0700
> > Subject: Re: multiple LTC1298
> > Any particular reason you don't want to use 8-channel ADCs such as
> LTC1290,
> > LTC1294, etc?
I
> > only would need one additional line for each extra ADC I add. Is there
any
but
> mostly
> > I use code snippets I find and start working my way thru them. Any info
> > insights would be most appreciated.<
> > Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
> > Manufacturer of the famous BOB-II Serial Video Text Display Module!
> > Message: 18
> > Date: Thu, 19 Apr 2001 09:11:46 +0200
> > Subject: sounds
> > If you're searching for sounds then a possibility could be to search for
> > ringtones for a mobile phone, differnt times i saw tunes that could be
> used
> > by a bs2
> > Get Your Private, Free E-mail from MSN Hotmail at
http://www.hotmail.com.
> > Message: 19
> > Date: Thu, 19 Apr 2001 20:07:03 +0800
> > I think this will do what you're after:
> > task_done VAR BIT
> > task_time VAR BYTE
> > task_interval CON 30 ' or whatever
> > [noparse][[/noparse] get min ]
> > IF min >= task_time THEN checkTask
> > task_done = 0
> > GOTO continue
> > checkTask:
> > IF task_done = 1 THEN continue
> > [noparse][[/noparse] do task ]
> > task_done = 1
> > task_time = task_time + task_interval // 60
> > continue:
> > Regards,
> > Steve
> > Message: 20
> > Date: Thu, 19 Apr 2001 23:25:15 EDT
> > In a message dated 4/19/01 7:19:17 PM Pacific Daylight Time,
> > decade@w... writes:
> LTC1290,
> > > LTC1294, etc?
> > I would definitly go that route in the future. On this project I have
> already
> > had 6 boards made and they are to accomodate the ltc 1298, what happened
> was
> > all of a sudden I found out I needed a bunch more ADC inputs then i had
> > counted on. This project has become a nightmare, I told my dad I could
> have
> > some equipment made for the company he works for, now the deadline is
here
> > and I still am trying to get the first prototype finished. I have not
> slept
> > comfortably in weeks [noparse]:([/noparse]
> > I am hoping on trying out the prototype tonight, so far there has been
all
> > sorts of things going wrong. I screwed up on a few of boards and had to
> slice
> > and jump traces. there are portions that I have not even tryed out yet.
> The
> > fun just never stops [noparse];)[/noparse]
> > back to work for me
> Message: 2
> Date: Fri, 20 Apr 2001 07:50:07 -0400
> Subject: RE: unsubscribe
> It's actually quite easy if you send email to:
Original Message
> From: Paul Gatcum [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ehiN_OcDNaD_LL--4ZmMsUNdQ2lYx8jFjZIUZqy_1bzesUnObjYszl7YNCLiFPKVGj4qvPYGBprhNYSh3A]pgatcum@n...[/url
> Sent: Friday, April 20, 2001 5:52 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Digest Number 608 unsubscribe
Original Message
> Message: 3
> Date: Fri, 20 Apr 2001 14:04:35 -0000
> From: bs2web@y...
> Hello. I have designed a STAMP "carrier" which is made to accomodate
> a 24 pin STAMP and has 8 8-bit ADC channnels, 8 extra I/O ports, RTC
> with built-in battery backup, up to 256k EEPROM, built-in 3-wire and
> I2C bus (with integrated pull-up resistors) and a programming port.
> Since you've already had some boards made, it most likely won't work
> with this project, but it could help on a future project. It would
> give you the extra ADC channels and give you some extra I/O.
> Details of the design are at: www.high-
> techgarage.com/products/supermax.php if you are interested.
> Good luck with your project!
> -- Jeff
> --{ www.high-techgarage.com }--
> --{ Why park your STAMP anywhere else? }--
> > decade@w... writes:
> as LTC1290,
> > > LTC1294, etc?
> have already
> happened was
> had
> could have
> is here
> not slept
> been all
> had to slice
> yet. The
> > back to work for me
> Message: 4
> Date: Fri, 20 Apr 2001 14:17:16 -0000
> Subject: Re: Freelance Programmers : Some clarifications
> I think you guys should take it outside and settle it like real men.
> Arghhh
> The written word is NOT speech. You have a chance to reflect..
> Don't be inflammatory, and then apologize for doing so. If flaming is
> what you like to do, then be proud of it.
> The USA is a free country. People are entitled to say what they
> please. This right is guaranteed by our constitution.
> them to
> you
> Have
> think
> AND,
> that you
> expect
> why
> and
> don'it ?!!
> in
> must
> you had
> hard
> to
> > somebody man!!
> > P.S:
> in
Original Message
> > [noparse][[/noparse]mailto:innovativeinstitute@s...]
> > To: elliot@u...; perl-beginner@y...;
> > basicstamps@y...; bschwabe@a...;
> > comdeveloper@y...; dohays@a...;
> > ACEWAREZ@y...; theresaradke@c...;
> > COLOS_Linux@y...; dave@q...
> > sknutson@l...; fresher_papers@y...
> various
> ATARI,
> early
> > field since 1979...
> to..
> their
> persons
> > will use it)
> various
> that
> must
> alone...
> my
> situation..
> > programmers... ???
> > egroups...
> > democracy...
> had
> better
> > understand...
First, are you sure the BS2 hasn't crapped out? can you program it
with any other boards
Secondly, are you 100% sure that all the connections are good? I've
spent 2 days pulling out my hair when an HC11 board I made wouldn't
program, until after 20 visual inspections of connections, I started
wiggling wires, and found one of the programing wires was a fraction
of a millimeter away from the pin/solder blob, and at an odd angle
that I never would have noticed without actually doing the 'wiggle
test'
Hope that helps..
~Roger~
TenFour
http://korus.cjb.net
