TWS Interface
I want to communicate with a Stamp from my PC keyboard via an RF link.
I need software that will let me send keystrokes directly to the serial port.
I need to know how to connect an interface IC - the Max232 - between the
serial port and the TWS input. The interface will be used for Transmit only.
Sid
Sid
Paul
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, March 26, 2001 4:20 PM
Subject: [noparse][[/noparse]basicstamps] TWS Interface
port.
only.
> Thanks
> Sid
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Sid
working on a project for school involving RF communication between a PC and
a BOEBot. It's coming along fairly well. I am using Visual Basic on the
PC. Anyway, I did some research on RF and decided to use the TWS/RWS from
Reynolds, and am also using a MAX233 as an intermediary between the RS-232
serial cable and the transmitter.
Good luck to everyone on all of their projects!
Paul Contino
Original Message
Sent: Monday, March 26, 2001 7:26 PM
Subject: Re: [noparse][[/noparse]basicstamps] TWS Interface
> Which one, Paul. there are four different kinds.
> Sid
is a little more expensive, but allows for a bit faster data transfer rate
(200 kbps vs. 120 kbps) and a higher slew rate (something to do with speed
of op-amp voltage change, all internal to the MAX IC). The "C" is for
commercial use (temperature range, which I think 0-70 degrees Celsius should
work just fine for most applications). The "PP" is for PDIP (Plastic
Dual-In-Line). I know that there is a "WIDE SO" version, but I am not sure
exactly what that means -- some of the pin outs are for a different use.
Hope this helps. That's all that I can tell you. Everything is on the
Maxim website [noparse][[/noparse] www.maxim-ic.com ]. Do a search for MAX233 and take a look
at the data sheet (PDF).
Good luck.
Paul
Original Message
> Sid
First thing first: why don't you guys use the DS275 from Dallas
instead of the MAX232 or MAX233? Much easier to use in my view!
Second, is there any way to send data with a BS2 at the transmitting
end to the receiver hooked to a DS275(max232) at the receiving end
have the stamp debug screen read the incoming info? If not, how do I
get hyperterminal to read the incoming info...or a QBasic routine?
Corey.
--- In basicstamps@y..., "Paul Contino" <continpf@e...> wrote:
> My bad. Which MAX233 do you ask? I chose the MAX233ACPP. The "A"
version
transfer rate
speed
Celsius should
not sure
a look
> Good luck.
> Paul
Original Message
> From: <Newzed@a...>
> To: <basicstamps@y...>
> > Sid
Why do I need a line driver/receiver? From what I can tell, many serial
ports will accept TTL levels as data in, and the Stamp manual itself has
an example of using a 22K resistor for data from a serial port to the
stamp. So, is it only when I must drive higer voltages from the stamp,
like for a serial port that won't accept TTL, or for greater cable
lengths? And why would a line receiver be better than a 22K resistor?
Anyone? I'm fairly hardware clueless.
Second, For the receiving end, I just hooked the data out of the RWS-434
directly to the input pin (pin 2 on a DB9) on the serial port and
connected the ground. Configured HyperTerminal for 2400b, 8N1. Just
worked.
Kevin
the_coin_guy@y... wrote:
> Hi all,
> Thanks,
> Corey.
> version
> transfer rate
> speed
> Celsius should
> not sure
> a look
> > Good luck.
> > Paul
Original Message
> > From: <Newzed@a...>
> > > Sid
level you should not.
FYI -- we used Max232's on some equipment where we used to work and got
500'+ distance at 300 baud. the new stuff used Max495's and we were able to
go 1500'+ at 9600 baud.
Original Message
> OK, I'll take a shot at the second if you can answer my other question.
> worked.
> If you need true PC variety RS232, you have to use a line driver. For TTL
I guess this is where my confusion is, the definition of 'true PC
variety RS232'. I've tried on 4 different PC, all where able to
directly read from the stamp, no line driver (all at short, < 4' cable
lengths). And assuming a short cable run is fine for a given
applicaiton so direct stamp->PC sems to work, what about PC->stamp. Do
you know of any badness from using the PC->22Kresistor->stamp method?
OK, this sounds like a good example of greater cable length needing
higher voltages.
Kevin
that I also have had great results with the DS275.
= Steve
>higher voltages.
>Thanks,
>Kevin
You might wind up toasting your stamp if you connect one of the regular data
ports to a PC serial port.
If you look at a schematic for the BS2 processors, you'll see the serial
port for the PC has a simple line driver built out of a few transistors.
Original Message
TTL
line driver at all.
Original Message
> I've not been following this thread too closely, but would like to throw
in
from the serial port, hence the 22k resistor (I imagine). Writing to
the serial port seems like it'd only work of the serial port was able to
accept the non-standard RS-232 voltages.
Still just wondering if I'm missing something here. Why does everyone
seem to jump to the added cost/component of a line driver?
Is this just a case of, "just because it works for me, in my situation,
doesn't mean it'll work for everyone, so always best to follow the
spec"?
ko
Rodent wrote:
> If I remember right, true RS232 is + / - 12 volts, where TTL is 0-5 volts.
Original Message
> TTL
in fact I just finished a project this evening that uses the 22K resistor
to protect the pic's( or stamp) internal protection diodes from blowing
apart. Any time you put a voltage greater then about 0.7 vdc above the
stamps supply voltage, typically 5 vdc,the internal diodes will begin to
conduct. This allows happens if you put a voltage less than -0.7 vdc below
ground.
The stamps internal protection diodes are rated for a maximum of 20
milliamps. I've run over 25 milliamps through the protection diodes for
several days to see if they would fail, and they did not.
So, If you put + 12 vdc on to your stamp pin through a 22 K resistor, then
the current would be about 12 vdc-5.7vdc= 6.3 vdc/22 K = 0.286 milliamps
through the protection diode, well within it's range and it should work
just fine.
It's also a good idea to use a resistor on your output pin, something
around 1 K to protect it from accidental shorts.
Most if not all pc's, included laptops should have no trouble recognizing
the stamp's output pin swing of 0 to +5 vdc.....
At 10:04 PM 03/27/2001 -0600, you wrote:
>We're not trying to dis the DS275, just trying to justify the need for any
>line driver at all.
Original Message
>in
For me the reason is reliability, I build projects for other people and
would hate to see a unit returned due to the loss of a protection diode.
Thanks to the PIC's robust I/O protection diodes, you can get away with it
most of the time..............Then again a line driver for $2 or $3 keeps
the pic happy.
fwiw
Steve
Kein
> the pic happy.
> fwiw
> Steve
the current revision) to define standards for interconnection of data
transmission equipment ("DTE", e.g. a computer) and data
communications equipment ("DCE", usually a modem). At the time DB-25
connectors were specified, a large number of wires were defined in the
cable (many optional) and many electrical requirements are specified.
The objective was to guarantee that if ports and cables met the
standard they could be safely interconnected and expected to work. The
following site, among many others,
http://www.rad.com/networks/1995/rs232/rs232.htm will tell yhou a lot
about the actual standard.
The computer industry later abandoned DB-25 in favor of the smaller
DB-9 connectors. This still allows enough connections to support
external modems but I don't think the RS-232 standard has actually
been modified to include this subset. The standard also requires the
signal sources to be between +3 and +12 when positive and -3 and -12
when negative. Receivers are supposed to tolerate up to +25 to -25
volts. But most, if not all, computers have been designed to accept
"TTL" signal inputs as well as "real" RS-232. TTL signals must be
relatively "clean" to work well.
Stamp pins do not meet the port requirements for RS-232 but driver
chips such as the MAX232 do. The driver chips are also compatible with
Stamp pins. Voila! A $3 interface that meets standards in both
directions and protects your Stamp. There are other workarounds, such
as adding resistors here and there, that will work in specific cases
but I wouldn't trust this for all situations without knowing the
details. The drivers are also increasingly useful for any combinations
of higher data rates and longer cables.
Cable capacitance causes signal distortion that increases with the
length of the cable. This typically (depending on the driver, the
receiver and the cable selected) supports RS-232 9600 baud
communications over at least 100 cable feet. Halve the distance every
time the rate is doubled or vice versa. However, the RS-232 standard
actually specifies cables only to a maximum of 50 feet. Your mileage
may vary.
I hope this backgound stuff helps.
--- In basicstamps@y..., Kevin Olalde <kolalde@h...> wrote:
> Yep, I'd certainly be worried about nuking the stamp trying to
_read_
to
able to
everyone
situation,
> spec"?
> ko
0-5 volts.
regular data
serial
transistors.
Original Message
driver. For
> > TTL
PC
cable
PC->stamp. Do
method?
computers today? (if there is such a place)
Robert Staph, W3RCS
The Center for Advanced Technologies
Original Message
Sent: Wednesday, March 28, 2001 9:15 AM
Subject: [noparse][[/noparse]basicstamps] Re: TWS Interface
> The RS-232 Standard was developed many years ago (RS-232C is, I think,
> may vary.
> _read_
> to
> able to
> everyone
> situation,
> > spec"?
> > ko
> 0-5 volts.
> regular data
> serial
> transistors.
Original Message
> driver. For
> > > TTL
> PC
> cable
> PC->stamp. Do
> method?
So I finished my cup of coffee, and then I said "Why go through all of this
TWS/Max232/22K resistor stuff?"
Pin 3 of the Stamp DB9 connector - the Tx pin - goes directly to the serin
pin on the Stamp module, which is really pin 16.
So at the very beginning of the Train program I wrote:
N9600 con 16468
com var byte
serin 16, N9600, [noparse][[/noparse]com]
if com = "A" then start1
if com = "B" then stop1 'and so on for a few more "if's"
Loaded the program into Stamp, exited the Stamp Editor to free up Com1 port,
the went to Hyperterminal. Hit A on the keyboard and Train 1 started up and
ran. Hit B on the keyboard and Train 1 stopped.
All so very simple once I had Hyperterminal - no wires, no TWS, no line
driver, I didn't even have to move the serial cable.
I can now make the train do anything I want it to just by hitting the right
letter on the keyboard.
Sid
I find www.google.com very good at looking up these kinds of things.
That's what I used to find RS-232 documents. Google should be very
effective if you know the name of the standard or at least an acronym
that is related.
But I can't help you with a centralized source for computer standards
in general.
Fred, K1IZM
--- In basicstamps@y..., "Robert Staph" <rstaph@a...> wrote:
> Can you point me to a web page that has alot of the standards used
in
> Robert Staph, W3RCS
Original Message
> From: <fdavidson@m...>
think,
data
DB-25
the
specified.
The
lot
smaller
the
-12
accept
with
such
cases
combinations
every
standard
mileage
> > may vary.
> > _read_
Writing
> > to
> > able to
> > everyone
> > situation,
the
> > > spec"?
> > > ko
is
> > 0-5 volts.
the
> > regular data
the
> > serial
> > transistors.
Original Message
> > driver. For
> > > > TTL
'true
> > PC
able to
< 4'
> > cable
given
> > PC->stamp. Do
> > method?
