TWS Interface — Parallax Forums
TWS Interface
edited 2001-03-29 20:14 in General Discussion
I want to communicate with a Stamp from my PC keyboard via an RF link.
I need software that will let me send keystrokes directly to the serial port.
I need to know how to connect an interface IC - the Max232 - between the
serial port and the TWS input. The interface will be used for Transmit only.
Sid
    edited 2001-03-26 23:54
    I would recommend a MAX233 -- no external capacitors necessary.
    Paul
    Sent: Monday, March 26, 2001 4:20 PM
    Subject: [noparse][[/noparse]basicstamps] TWS Interface
    port.
    only.
    > Thanks
    > Sid
    edited 2001-03-27 01:26
    Which one, Paul. there are four different kinds.
    Sid
    edited 2001-03-27 03:22
    Hi. My name is Paul Contino. I am new to Basic Stamps. Currently I am
    working on a project for school involving RF communication between a PC and
    a BOEBot. It's coming along fairly well. I am using Visual Basic on the
    PC. Anyway, I did some research on RF and decided to use the TWS/RWS from
    Reynolds, and am also using a MAX233 as an intermediary between the RS-232
    serial cable and the transmitter.
    Good luck to everyone on all of their projects!
    Paul Contino
    Sent: Monday, March 26, 2001 7:26 PM
    Subject: Re: [noparse][[/noparse]basicstamps] TWS Interface
    > Sid
    edited 2001-03-27 03:55
    My bad. Which MAX233 do you ask? I chose the MAX233ACPP. The "A" version
    is a little more expensive, but allows for a bit faster data transfer rate
    (200 kbps vs. 120 kbps) and a higher slew rate (something to do with speed
    of op-amp voltage change, all internal to the MAX IC). The "C" is for
    commercial use (temperature range, which I think 0-70 degrees Celsius should
    work just fine for most applications). The "PP" is for PDIP (Plastic
    Dual-In-Line). I know that there is a "WIDE SO" version, but I am not sure
    exactly what that means -- some of the pin outs are for a different use.
    Hope this helps. That's all that I can tell you. Everything is on the
    Maxim website [noparse][[/noparse] www.maxim-ic.com ]. Do a search for MAX233 and take a look
    at the data sheet (PDF).
    Good luck.
    Paul
    > Sid
    edited 2001-03-28 01:57
    Hi all,
    First thing first: why don't you guys use the DS275 from Dallas
    instead of the MAX232 or MAX233? Much easier to use in my view!
    Second, is there any way to send data with a BS2 at the transmitting
    end to the receiver hooked to a DS275(max232) at the receiving end
    have the stamp debug screen read the incoming info? If not, how do I
    get hyperterminal to read the incoming info...or a QBasic routine?
    Corey.
    version
    transfer rate
    speed
    Celsius should
    not sure
    a look
    > Good luck.
    > Paul
    > From: <Newzed@a...>
    > To: <basicstamps@y...>
    > > Sid
    edited 2001-03-28 04:07
    OK, I'll take a shot at the second if you can answer my other question.
    Why do I need a line driver/receiver? From what I can tell, many serial
    ports will accept TTL levels as data in, and the Stamp manual itself has
    an example of using a 22K resistor for data from a serial port to the
    stamp. So, is it only when I must drive higer voltages from the stamp,
    like for a serial port that won't accept TTL, or for greater cable
    lengths? And why would a line receiver be better than a 22K resistor?
    Anyone? I'm fairly hardware clueless.
    Second, For the receiving end, I just hooked the data out of the RWS-434
    directly to the input pin (pin 2 on a DB9) on the serial port and
    connected the ground. Configured HyperTerminal for 2400b, 8N1. Just
    worked.
    Kevin
    the_coin_guy@y... wrote:
    > Hi all,
    > Thanks,
    > Corey.
    > version
    > transfer rate
    > speed
    > Celsius should
    > not sure
    > a look
    > > Good luck.
    > > Paul
    > > From: <Newzed@a...>
    > > > Sid
    edited 2001-03-28 04:46
    If you need true PC variety RS232, you have to use a line driver. For TTL
    level you should not.
    FYI -- we used Max232's on some equipment where we used to work and got
    500'+ distance at 300 baud. the new stuff used Max495's and we were able to
    go 1500'+ at 9600 baud.
    > worked.
    edited 2001-03-28 04:54
    I guess this is where my confusion is, the definition of 'true PC
    variety RS232'. I've tried on 4 different PC, all where able to
    directly read from the stamp, no line driver (all at short, < 4' cable
    lengths). And assuming a short cable run is fine for a given
    applicaiton so direct stamp->PC sems to work, what about PC->stamp. Do
    you know of any badness from using the PC->22Kresistor->stamp method?
    OK, this sounds like a good example of greater cable length needing
    higher voltages.
    Kevin
    edited 2001-03-28 04:59
    I've not been following this thread too closely, but would like to throw in
    that I also have had great results with the DS275.
    = Steve
    >higher voltages.
    >Thanks,
    >Kevin
    edited 2001-03-28 05:03
    If I remember right, true RS232 is + / - 12 volts, where TTL is 0-5 volts.
    You might wind up toasting your stamp if you connect one of the regular data
    ports to a PC serial port.
    If you look at a schematic for the BS2 processors, you'll see the serial
    port for the PC has a simple line driver built out of a few transistors.
    TTL
    edited 2001-03-28 05:04
    We're not trying to dis the DS275, just trying to justify the need for any
    line driver at all.
    in
    edited 2001-03-28 05:18
    Yep, I'd certainly be worried about nuking the stamp trying to _read_
    from the serial port, hence the 22k resistor (I imagine). Writing to
    the serial port seems like it'd only work of the serial port was able to
    accept the non-standard RS-232 voltages.
    Still just wondering if I'm missing something here. Why does everyone
    seem to jump to the added cost/component of a line driver?
    Is this just a case of, "just because it works for me, in my situation,
    doesn't mean it'll work for everyone, so always best to follow the
    spec"?
    ko
    > TTL
    edited 2001-03-28 05:40
    No trouble, For many applications you can get away without a line driver,
    in fact I just finished a project this evening that uses the 22K resistor
    to protect the pic's( or stamp) internal protection diodes from blowing
    apart. Any time you put a voltage greater then about 0.7 vdc above the
    stamps supply voltage, typically 5 vdc,the internal diodes will begin to
    conduct. This allows happens if you put a voltage less than -0.7 vdc below
    ground.
    The stamps internal protection diodes are rated for a maximum of 20
    milliamps. I've run over 25 milliamps through the protection diodes for
    several days to see if they would fail, and they did not.
    So, If you put + 12 vdc on to your stamp pin through a 22 K resistor, then
    the current would be about 12 vdc-5.7vdc= 6.3 vdc/22 K = 0.286 milliamps
    through the protection diode, well within it's range and it should work
    just fine.
    It's also a good idea to use a resistor on your output pin, something
    around 1 K to protect it from accidental shorts.
    Most if not all pc's, included laptops should have no trouble recognizing
    the stamp's output pin swing of 0 to +5 vdc.....
    >line driver at all.
    >in
    edited 2001-03-28 05:47
    For me the reason is reliability, I build projects for other people and
    would hate to see a unit returned due to the loss of a protection diode.
    Thanks to the PIC's robust I/O protection diodes, you can get away with it
    most of the time..............Then again a line driver for $2 or $3 keeps
    the pic happy.
    fwiw
    Steve
    edited 2001-03-28 06:26
    cool, thanks.
    Kein
    > the pic happy.
    > fwiw
    > Steve
    edited 2001-03-28 15:15
    The RS-232 Standard was developed many years ago (RS-232C is, I think,
    the current revision) to define standards for interconnection of data
    transmission equipment ("DTE", e.g. a computer) and data
    communications equipment ("DCE", usually a modem). At the time DB-25
    connectors were specified, a large number of wires were defined in the
    cable (many optional) and many electrical requirements are specified.
    The objective was to guarantee that if ports and cables met the
    standard they could be safely interconnected and expected to work. The
    following site, among many others,
    http://www.rad.com/networks/1995/rs232/rs232.htm will tell yhou a lot
    about the actual standard.
    The computer industry later abandoned DB-25 in favor of the smaller
    DB-9 connectors. This still allows enough connections to support
    external modems but I don't think the RS-232 standard has actually
    been modified to include this subset. The standard also requires the
    signal sources to be between +3 and +12 when positive and -3 and -12
    when negative. Receivers are supposed to tolerate up to +25 to -25
    volts. But most, if not all, computers have been designed to accept
    "TTL" signal inputs as well as "real" RS-232. TTL signals must be
    relatively "clean" to work well.
    Stamp pins do not meet the port requirements for RS-232 but driver
    chips such as the MAX232 do. The driver chips are also compatible with
    Stamp pins. Voila! A $3 interface that meets standards in both
    directions and protects your Stamp. There are other workarounds, such
    as adding resistors here and there, that will work in specific cases
    but I wouldn't trust this for all situations without knowing the
    details. The drivers are also increasingly useful for any combinations
    of higher data rates and longer cables.
    Cable capacitance causes signal distortion that increases with the
    length of the cable. This typically (depending on the driver, the
    receiver and the cable selected) supports RS-232 9600 baud
    communications over at least 100 cable feet. Halve the distance every
    time the rate is doubled or vice versa. However, the RS-232 standard
    actually specifies cables only to a maximum of 50 feet. Your mileage
    may vary.
    I hope this backgound stuff helps.
    _read_
    to
    able to
    everyone
    situation,
    > spec"?
    > ko
    0-5 volts.
    regular data
    serial
    transistors.
    driver. For
    > > TTL
    PC
    cable
    PC->stamp. Do
    method?
    edited 2001-03-28 15:24
    Can you point me to a web page that has alot of the standards used in
    computers today? (if there is such a place)
    Robert Staph, W3RCS
    The Center for Advanced Technologies
    Sent: Wednesday, March 28, 2001 9:15 AM
    Subject: [noparse][[/noparse]basicstamps] Re: TWS Interface
    > may vary.
    > _read_
    > to
    > able to
    > everyone
    > situation,
    > > spec"?
    > > ko
    > 0-5 volts.
    > regular data
    > serial
    > transistors.
    > driver. For
    > > > TTL
    > PC
    > cable
    > PC->stamp. Do
    > method?
    edited 2001-03-28 21:27
    Good afternoon, Sir Kevin
    So I finished my cup of coffee, and then I said "Why go through all of this
    TWS/Max232/22K resistor stuff?"
    Pin 3 of the Stamp DB9 connector - the Tx pin - goes directly to the serin
    pin on the Stamp module, which is really pin 16.
    So at the very beginning of the Train program I wrote:
    N9600 con 16468
    com var byte
    serin 16, N9600, [noparse][[/noparse]com]
    if com = "A" then start1
    if com = "B" then stop1 'and so on for a few more "if's"
    Loaded the program into Stamp, exited the Stamp Editor to free up Com1 port,
    the went to Hyperterminal. Hit A on the keyboard and Train 1 started up and
    ran. Hit B on the keyboard and Train 1 stopped.
    All so very simple once I had Hyperterminal - no wires, no TWS, no line
    driver, I didn't even have to move the serial cable.
    I can now make the train do anything I want it to just by hitting the right
    letter on the keyboard.
    Sid
    Hi Bob,
    I find www.google.com very good at looking up these kinds of things.
    That's what I used to find RS-232 documents. Google should be very
    effective if you know the name of the standard or at least an acronym
    that is related.
    But I can't help you with a centralized source for computer standards
    in general.
    Fred, K1IZM
    in
    > Robert Staph, W3RCS
    > From: <fdavidson@m...>
    think,
    data
    DB-25
    the
    specified.
    The
    lot
    smaller
    the
    -12
    accept
    with
    such
    cases
    combinations
    every
    standard
    mileage
    > > may vary.
    > > _read_
    Writing
    > > to
    > > able to
    > > everyone
    > > situation,
    the
    > > > spec"?
    > > > ko
    is
    > > 0-5 volts.
    the
    > > regular data
    the
    > > serial
    > > transistors.
    > > driver. For
    > > > > TTL
    'true
    > > PC
    able to
    < 4'
    > > cable
    given
    > > PC->stamp. Do
    > > method?
