Serial Clock chip
Has anyone seen code or schematics to connect a Serial clock chip to the
StampII ? In particular I am interested in the NJU6355.
Roy Hall
* Roy Hall, Senior N8VRC, CET *
* Email: leroy @fuse.net *
* URL: http://home.fuse.net/leroy/resume.htm *
* Roy Hall *
* 317 Cherokee Drive *
* Loveland, Ohio - USA 45140-2404 *
Roy Hall
* Roy Hall *
StampII ?
Roy Hall
Do you have a particular clock in mind? There are lots of code examples
floating around.
Try a search at http://www.jamesrusso.com/stamp/search.html for RTC, or
better yet search for NJU6355 and DS1302, two popular serial clocks.
see if that gets you going,
Steve
At 10:38 PM 02/16/2001 -0500, you wrote:
>StampII ?
>Thanks,
>Roy Hall
>StampII ?
>Thanks,
>Roy Hall
Scott Edwards has posted the manual for the DCPB (data collection
proto board) on his web site <http://www.seetron.com>. It shows a
schematic and software for the NJU6533 clock chip (available from
digikey). Parallax sells the app-kit for the DS1302, which is a
slightly more capable chip, but also more $$.
-- Tracy
I have code for the DS1307 I2C serial clock chip. The chip and
crystal are available from Peter Anderson (www.phanderson.com) for a
very reasonable price!
--Jeff Wallace
High-TechGarage
to the
> StampII ?
> Thanks,
> Roy Hall
