16 Chars LCD Display on stamp1
Does anybody know how to address the "other" 8 characters on a std
Hitachi 1 x 16 Chars LCD.
Using the example from the parallax book i'm able to display some
text on the first part of the display but nothing happens on the
other block.
I tried to use the 128 + 64 in the char but this doesn't seem to work
Thanks!
other block.
Thanks!
addressed as a second line. Mine work OK by sending 254,192. The 254 tells
the Hitachi that a command is to follow, and the 192 is the 2nd line
command.
Good luck,
Ray McArthur
Original Message
To: <basicstamps@egroups.com>
Sent: Wednesday, January 10, 2001 4:48 PM
Subject: [noparse][[/noparse]basicstamps] 16 Chars LCD Display on stamp1
> other block.
> Thanks!
--- In basicstamps@egroups.com, "Ray McArthur" <rjmca@u...> wrote:
> One line displays usually split the line in two, with the last half
being
254 tells
> command.
> Good luck,
> Ray McArthur
Original Message
> From: Hennie Vos <vos@s...>
> > other block.
work
> > Thanks!
I thought you were using a serial interface to your LCD. If you are running
"LCD Interface-terminal" in the Stamp manual, the 254, 192 sequence is what
you need, but I don't know offhand how to insert them into the code.
Sorry,
Ray McArthur
Original Message
Sent: Friday, January 12, 2001 2:11 PM
Subject: [noparse][[/noparse]basicstamps] Re: 16 Chars LCD Display on stamp1
> On a stamp1 254,192 ?
> being
> 254 tells
> > command.
> > Good luck,
> > Ray McArthur
Original Message
> > > other block.
> work
> Hennie
are running
is what
> Sorry,
> Ray McArthur
Original Message
half
> > being
The
> > 254 tells
line
> > > command.
> > > Good luck,
> > > Ray McArthur
Original Message
a std
some
the
> > > > other block.
to
> > work
I can send you a piece of code from a 2x 16 display, hooked up like
example 1 in the stamp-1 manual. I use it for the stamp-II with
succes.
It means that I have hooked it up using the plain conection to the
display (14 wires total).
Jugo
pd0ffm@a...
> other block.
work
> Thanks!
