16 Chars LCD Display on stamp1 — Parallax Forums
edited 2001-01-24 23:07 in General Discussion
Does anybody know how to address the "other" 8 characters on a std
Hitachi 1 x 16 Chars LCD.
Using the example from the parallax book i'm able to display some
text on the first part of the display but nothing happens on the
other block.
I tried to use the 128 + 64 in the char but this doesn't seem to work
Thanks!
    edited 2001-01-11 00:40
    One line displays usually split the line in two, with the last half being
    addressed as a second line. Mine work OK by sending 254,192. The 254 tells
    the Hitachi that a command is to follow, and the 192 is the 2nd line
    command.
    Good luck,
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Wednesday, January 10, 2001 4:48 PM
    Subject: [noparse][[/noparse]basicstamps] 16 Chars LCD Display on stamp1
    > other block.
    > Thanks!
    edited 2001-01-12 19:11
    On a stamp1 254,192 ?
    being
    254 tells
    > command.
    > Good luck,
    > Ray McArthur
    > From: Hennie Vos <vos@s...>
    > > other block.
    work
    > > Thanks!
    edited 2001-01-12 21:13
    Hennie
    I thought you were using a serial interface to your LCD. If you are running
    "LCD Interface-terminal" in the Stamp manual, the 254, 192 sequence is what
    you need, but I don't know offhand how to insert them into the code.
    Sorry,
    Ray McArthur
    Sent: Friday, January 12, 2001 2:11 PM
    Subject: [noparse][[/noparse]basicstamps] Re: 16 Chars LCD Display on stamp1
    > being
    > 254 tells
    > > command.
    > > Good luck,
    > > Ray McArthur
    > > > other block.
    > work
    edited 2001-01-12 21:38
    No money for the backpack display, plain LCD with hitachi chip on it.
    > Hennie
    are running
    is what
    > Sorry,
    > Ray McArthur
    half
    > > being
    The
    > > 254 tells
    line
    > > > command.
    > > > Good luck,
    > > > Ray McArthur
    a std
    some
    the
    > > > > other block.
    to
    > > work
    Dear Hennie, (your name sounds very Dutch)
    I can send you a piece of code from a 2x 16 display, hooked up like
    example 1 in the stamp-1 manual. I use it for the stamp-II with
    succes.
    It means that I have hooked it up using the plain conection to the
    display (14 wires total).
    Jugo
    pd0ffm@a...
    > other block.
    work
    > Thanks!
