Distance & Speed Measurer, Wireless
I have an need for a device that does the following:
Counts a pulse (from a disk that has ~20 magnets)
Processes the info (pulses to inches, pulses to mph)
If mph = X then close relay
Transmit data to another stamp (using the rf modules from parallax)
I know that this is all possible, but I have never used a stamp
before, and have only a little electronics knowledge.
Your help is appreciated,
Marlin Schrock
Marlin Schrock
speed and time accuracy. Refer Stamp manual for COUNT command. You also
will need a Hall effec magnetic sensor. Remember also integer 16 bit
math of Stamp. If you have the Stamp, all the parts and time go ahead.We
will help if you ask.
ACJacques
> Marlin Schrock
Hi Marlin -
Essentially you are describing a Hall Effect sensor. One source for suchsensors is Allegro Micro at [noparse]/noparse][url=http://www.allegro-micro.com/]http://www.allegro-micro.com[/url. You might check their Selector Guide of Sensors at:
·············· [noparse][[/noparse] http://www.allegromicro.com/selguide/hed1.htm ]
[font=Arial, Helvetica]The UGQ5140K unipolar Hall effect switch is a monolithic integrated circuit designed for magnetic actuation of low-power incandescent lamps or inductive loads such as relays or solenoids. Included on chip is a Darlington power output that is capable of continuously sinking in excess of 300 mA. Internal protection circuitry limits surge (lamp turn-ON) or fault currents to approximately 900 mA.
A sensitive magnetic threshold allows the device to be used in con-junction with inexpensive magnets or in applications that require relatively large operating distances.
[/font]
Bruce Bates
count the pulses in 1 second and divide by 20, you will get rotations per
second.
multiply by 6.28 to get rad/s.
v=w * r
v=linear velocity (m/s)
w=angular velocity (rad/s)
r=radius (m)
you will get m/s.
multiply by 2.2369 to convert to mph.
be sure that its sensor supports the maximum rotation and that doesn't have
skidding.
sds
Fabiano
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, November 21, 2000 10:10 AM
Subject: [noparse][[/noparse]basicstamps] Distance & Speed Measurer, Wireless
> Marlin Schrock
I have been trying to come up with a similar solution for counting pulses.
Has anyone tried to use the Hamamatsu P5587 Photoreflector with the Basic
Stamp? (I have a bunch of these and have seen them used on the Rug Warrior
Pro robots).
What I have so far is printed encoder wheels that have black strips on it
with a white background attached to each wheel.
Original Message
Sent: Tuesday, November 21, 2000 8:30 AM
Subject: Re: [noparse][[/noparse]basicstamps] Distance & Speed Measurer, Wireless
> To obtain the speed:
> second.
> v=w * r
> r=radius (m)
> you will get m/s.
have
> skidding.
> sds
> Fabiano
Original Message
> From: <ih_660@y...>
> > Marlin Schrock
