Distance & Speed Measurer, Wireless — Parallax Forums
edited 2000-11-21 22:10 in General Discussion
I have an need for a device that does the following:
Counts a pulse (from a disk that has ~20 magnets)
Processes the info (pulses to inches, pulses to mph)
If mph = X then close relay
Transmit data to another stamp (using the rf modules from parallax)
I know that this is all possible, but I have never used a stamp
before, and have only a little electronics knowledge.
Your help is appreciated,
Marlin Schrock
    edited 2000-11-21 12:32
    This is very straighforward for a Stamp. The only limitations will be
    speed and time accuracy. Refer Stamp manual for COUNT command. You also
    will need a Hall effec magnetic sensor. Remember also integer 16 bit
    math of Stamp. If you have the Stamp, all the parts and time go ahead.We
    will help if you ask.
    ACJacques
    > Marlin Schrock
    edited 2000-11-21 13:11
    At 12:10 PM 11/21/2000 +0000, you wrote:
    Hi Marlin -
    I have an need for a device that does thefollowing:
    Essentially you are describing a Hall Effect sensor. One source for suchsensors is Allegro Micro at [noparse]/noparse][url=http://www.allegro-micro.com/]http://www.allegro-micro.com[/url. You might check their Selector Guide of Sensors at:
    ·············· [noparse][[/noparse] http://www.allegromicro.com/selguide/hed1.htm ]
    Allegro makes a specific sensor/driver for activating solenoids or lamps. Per their documentation of the chip:
    [font=Arial, Helvetica]The UGQ5140K unipolar Hall effect switch is a monolithic integrated circuit designed for magnetic actuation of low-power incandescent lamps or inductive loads such as relays or solenoids. Included on chip is a Darlington power output that is capable of continuously sinking in excess of 300 mA. Internal protection circuitry limits surge (lamp turn-ON) or fault currents to approximately 900 mA.
    A sensitive magnetic threshold allows the device to be used in con-junction with inexpensive magnets or in applications that require relatively large operating distances.
    [/font]
    Just shout if you need more assistance. I trust you have the Stamp PBASIC Manual and the Stamp Editor (Windows and Mac versions are available for free). If not they can be downloaded for the Parallax web site [noparse][[/noparse] http://www.parallaxinc.com ] in the Documentation Section.
    Marlin Schrock
    Bruce Bates
    edited 2000-11-21 13:30
    To obtain the speed:
    count the pulses in 1 second and divide by 20, you will get rotations per
    second.
    multiply by 6.28 to get rad/s.
    v=w * r
    v=linear velocity (m/s)
    w=angular velocity (rad/s)
    r=radius (m)
    you will get m/s.
    multiply by 2.2369 to convert to mph.
    be sure that its sensor supports the maximum rotation and that doesn't have
    skidding.
    sds
    Fabiano
    To: <basicstamps@egroups.com>
    Sent: Tuesday, November 21, 2000 10:10 AM
    Subject: [noparse][[/noparse]basicstamps] Distance & Speed Measurer, Wireless
    > Marlin Schrock
    Hi.
    I have been trying to come up with a similar solution for counting pulses.
    Has anyone tried to use the Hamamatsu P5587 Photoreflector with the Basic
    Stamp? (I have a bunch of these and have seen them used on the Rug Warrior
    Pro robots).
    What I have so far is printed encoder wheels that have black strips on it
    with a white background attached to each wheel.
    Sent: Tuesday, November 21, 2000 8:30 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Distance & Speed Measurer, Wireless
    > second.
    > v=w * r
    > r=radius (m)
    > you will get m/s.
    have
    > skidding.
    > sds
    > Fabiano
    > From: <ih_660@y...>
    > > Marlin Schrock
