switch with a bs2
hello all,
I want to switch a external machine with my bs2. Kind of replace the on/off
switch of this peace of equipment. the current is low, voltage too.
A relais could be perfect for this, bs2 runs the relais, relais contacts
switch the machine. But this is not what i want! Are there other
possibilities? Could i use a optocoupler for instance? or even a transistor?
thanks pieter-jan
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
thanks pieter-jan
logic pulses.
Dennis
Original Message
From: Pieter-Jan van Diepen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YH56A8miFxTdzu9QhsZIm7Hj906lJB1-2Stx8FxFdt1eZ0syE0wm69Y-AiqIjs5BH1TBWejiqIvFkA]diepenpj@h...[/url
Sent: Friday, November 17, 2000 3:03 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] switch with a bs2
hello all,
thanks pieter-jan
are also solid-state relays for DC switching. If you use the right type,
they can be driven directly from a Stamp output ... they also provide
isolation.
Hope this helps,
Ray McArthur
Original Message
To: <basicstamps@egroups.com>
Sent: Friday, November 17, 2000 6:03 AM
> hello all,
on/off
transistor?
> thanks pieter-jan
