Boe-bot chassis
Hello,
Could someone please measure their Boe-Bot chassis. All I need is outside
length, width, height. I have one ordered, but need to know the size. The online
pdf is a dwg? I cannot find anything I have to open it.
Rick Rowland
Norland Research
http://www.smallrobot.com
Rick Rowland
Norland Research
>Hello,
online
This is an Autocad drawing file. There are CAD viewer type programs around
that will open it if you don't have any Autodesk products.
Duncan
The dimension as follows :
Length : 127 mm
Height : 36.8 mm
Width : 32.6 mm
I had the dwg file, let me know if you're interested.
Regards
Gary
DIY Electronics
Website : http://www.diyelectronics.com
Email : Gary.Chung@d...
Original Message
To: <basicstamps@egroups.com>
Sent: Sunday, October 29, 2000 1:21 AM
Subject: [noparse][[/noparse]basicstamps] Boe-bot chassis
> Hello,
online
> Rick Rowland
> Norland Research
from the dwg file. Let me know which format you're interested
in.
Regards
Gary
Original Message
Sent: Sunday, October 29, 2000 3:00 AM
Subject: Re: [noparse][[/noparse]basicstamps] Boe-bot chassis
> Hello Rick,
> Length : 127 mm
> Height : 36.8 mm
> Width : 32.6 mm
> Regards
> Gary
> DIY Electronics
Original Message
> From: "rick rowland" <see3peoh@i...>
> > Hello,
online
> > Rick Rowland
> > Norland Research
guess it is about 90-100 mm wide?
Rick
--- In basicstamps@egroups.com, "Gary Chung" <gary.chung@d...> wrote:
> Hello Rick,
> Length : 127 mm
> Height : 36.8 mm
> Width : 32.6 mm
> Regards
> Gary
> DIY Electronics
Original Message
> > Hello,
outside
size. The online
> > Rick Rowland
> > Norland Research
Sorry, the width should read 82.6mm and not 32.6 mm.
My eyelids was probably too heavy :-)
Regards
Gary
> > Hello Rick,
> > Length : 127 mm
> > Height : 36.8 mm
> > Width : 32.6 mm
> > Regards
> > Gary
> > DIY Electronics
Original Message
> > > Hello,
> outside
> size. The online
> > > Rick Rowland
> > > Norland Research
related to AutoDesk/AutoCad).
You can find a freeware version here http://www.cimmetry.com/index.html
It will view just about all vector and raster graphic file types as well as
many others.
Original Message
From: orthner@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SPCADiPJVWT0FW_wHlsaEE0E5YEtxdwShyIKsdJQIOroW7ZhQZ_lHsvdY4fUD03dteaYetkZVNfNSDIn]orthner@s...[/url
Sent: Saturday, October 28, 2000 11:26 AM
To: basicstamps@egroups.com
At 10:21 AM 10/28/00 -0700, you wrote:
>Hello,
online
Duncan
