Load cell
Hi,
Has anyone used a load cell with a Stamp?
I'm interested in measuring a spring pressure
and figured a load cell would be a very good
canidate for the application.
Dave
Dave
output an analog value proportional to pressure. Some signal
conditioning may be required to bring the voltage span into a good
range for the A/D you may be using.
Some load cells are just resistors (strain gauges) which may be used
as a leg of balanced bridge, or possible used in an RCTime function.
Just pick out a load cell that meets your needs, and how you want to
apply it. They come in many 'flavors'.
Use S-Plot Pro to graphically represent your data!
Martin Hebel
SelmaWare Solitions and Southern Illinois University Carbondale
http://www.selmaware.com/s-plot
--- In basicstamps@egroups.com, davemucha@j... wrote:
> Hi,
> Thanks,
> Dave
1B32 from Analog Devices.
LTC2400 from Linear Technology is A/D for weigh scale applications,look at
data sheet,there is a code for BS2.
AD7730 is a complete device accepts signal directly from load cell and
outputs a serial digital word .
Regards
Mohamed Refky
>From: davemucha@j...
>Reply-To: basicstamps@egroups.com
>Subject: [noparse][[/noparse]basicstamps] Load cell
>Date: Sat, 23 Sep 2000 04:42:09 -0000
>Hi,
>Thanks,
>Dave
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
I am interested in this application.
Can you guide me to any site that show
details of this project?
Thnak you.
Sze Keat
---Alan Paine <apaine.musem@m...> wrote:
> dave, yes people have used stamps on load cells , i sell new and
used load
> cells of every type let me know if you should need some. alan
Original Message
> From: <davemucha@j...>
> To: <basicstamps@egroups.com>
> Sent: Friday, September 22, 2000 9:42 PM
> > Hi,
> > Thanks,
> > Dave
DO YOU YAHOO!?
Original Message
> Hi,
> Thanks,
> Dave
alan
Original Message
Sent: Saturday, October 21, 2000 7:42 PM
Subject: Re: [noparse][[/noparse]basicstamps] Load cell
> Hello Alan
> Thnak you.
> Sze Keat
> used load
Original Message
> > > Hi,
> > > Thanks,
> > > Dave
> DO YOU YAHOO!?
> ̵ÎÁ¥ª¥ó¥é¥¤¥ó¥«¥ì¥ó¥À¡¼ --> http://calendar.yahoo.co.jp
+- 1% accuracy.
DOes any one know of some good load cells? The cheapest I have seen are about
$300. Which is a bit more than I hope to pay.
>I am looking for an inexpensive load cell, for the range on the order of
>20 lbs, +- 1% accuracy.
Can you use an inexpensive digital weigh scale? Most of those use a strain
gauge / load cell that is reasonably sensitive, coupled to a lever system
that transforms the scale range to that of the measurement beam. You would
have to modify those levers to give you the range that you need.
I've done this in the past - it was not very difficult.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
< http://www.ttloadcells.com/blc.htm >
They have a couple under $100.
I have used several without problems, but not for several years.
They have a much larger product line now with most in the $300
and up range.
Don Zacharie
"Dave Mucha " wrote:
> search for strain gauge too. you may find more links.
> what pressures are you looking to measure ?
> what prices are you finding and looking for ?
> E-bay has some for less than $50.00.
> Dave
