GPS --> BS2 Stamp (Plus Antenna)
Hi all,
I'm just after receiving my first GPS receiver, so I have a couple of
questions regarding interfacing the Gps to the stamp, will I need
some sort of conversion software (code) so the stamp can read the
data from the GPS.
Also what sort of antenna should I use. (would an antenna from a
mobile phone do the job)
thanks in advance
paul
data from the GPS.
thanks in advance
paul
> questions regarding interfacing the Gps to the stamp, will I need some
> sort of conversion software (code) so the stamp can read the data from the
> GPS.
There are all kinds of code snippets floating around to read NMEA
data streams from GPS devices. I don't have one handy, but a
search of this list's past posts or Deja News should turn-up more
than a few.
One specifically intended for your GPS. You can actually build
one, but it's not a great performer and I wouldn't recommend it as a
project if you're not familiar with microwave frequency radio.
> mobile phone do the job) thanks in advance paul
Definately not.
see: http://www.hvwtech.com/learning.htm
Our Learning Centre has some top-notch links for GPS. I'm sure
you'll find more specifi info in there.
Mark Hillier, VE6HVW
President, HVW Technologies Inc.
Canadian Distributors of Parallax Products and other Neat Stuff
Tel: +403-730-8603 Fax: +403-730-8903
NEWLY RENOVATED web site: http://www.hvwtech.com
GPS.
NMEA is ASCII at 4800 baud. You'll probably have to parse on the fly since
the STAMP doesn't have enough memory to store all the strings.
> Also what sort of antenna should I use. (would an antenna from a mobile phone
Some require an active antenna with a minimum gain rating. Others will
work with a passive. You can get a passive patch antenna module from Digi-
Key.
