GPS --> BS2 Stamp (Plus Antenna) — Parallax Forums
edited 2000-10-16 22:19 in General Discussion
Hi all,
I'm just after receiving my first GPS receiver, so I have a couple of
questions regarding interfacing the Gps to the stamp, will I need
some sort of conversion software (code) so the stamp can read the
data from the GPS.
Also what sort of antenna should I use. (would an antenna from a
mobile phone do the job)
thanks in advance
paul
    edited 2000-10-16 21:14
    > Hi all,
    > questions regarding interfacing the Gps to the stamp, will I need some
    > sort of conversion software (code) so the stamp can read the data from the
    > GPS.
    There are all kinds of code snippets floating around to read NMEA
    data streams from GPS devices. I don't have one handy, but a
    search of this list's past posts or Deja News should turn-up more
    than a few.
    One specifically intended for your GPS. You can actually build
    one, but it's not a great performer and I wouldn't recommend it as a
    project if you're not familiar with microwave frequency radio.
    > mobile phone do the job) thanks in advance paul
    Definately not.
    see: http://www.hvwtech.com/learning.htm
    Our Learning Centre has some top-notch links for GPS. I'm sure
    you'll find more specifi info in there.
    Mark Hillier, VE6HVW
    President, HVW Technologies Inc.
    Canadian Distributors of Parallax Products and other Neat Stuff
    Tel: +403-730-8603 Fax: +403-730-8903
    NEWLY RENOVATED web site: http://www.hvwtech.com
    > Hi all,
    GPS.
    NMEA is ASCII at 4800 baud. You'll probably have to parse on the fly since
    the STAMP doesn't have enough memory to store all the strings.
    > Also what sort of antenna should I use. (would an antenna from a mobile phone
    Some require an active antenna with a minimum gain rating. Others will
    work with a passive. You can get a passive patch antenna module from Digi-
    Key.
