Basic Stamp II
I am trying to build an automatic dawn simulator. I want it to start
gradually brightening a light over a period of 30 minutes, where it
will reach it's peak brightness. I have the Basic stamp 2 starter
kit, a DS1302 real time clock, and a triac. The plan is that when the
clock hits a given time the microprocessor will start slowly
adjusting the firing angle to the triac which will step up the
voltage given to the light. My problem is that I am not sure how to
handle the programming. Any help on what commands I should use in
order to control the triac would be greatly appreciated.
Josh
jbw0592@n...
Josh
jbw0592@n...
> Thanks,
> Josh
> jbw0592@n...
you will probably want to look at setting up an opto-daic to fire the
triac, i have built dimmer packs before and the way i did it was to have
the basic stamp give a value to an eight bit d/a chip, that fed the
analog dimmer packs, the analog dimmers consisted of a compairitor with
one input tied to a ramp circuit that was triggered and the ac zero
crossing, the other would be the analog control signal, the compairitor
fired an opto-diac which fired 4 trac's in parallel to get a channel
rating of 2.4kw, if your interested i can did up the part numbers
lw
