Basic Stamp II — Parallax Forums
Basic Stamp II
edited 2000-10-12 03:24 in General Discussion
I am trying to build an automatic dawn simulator. I want it to start
gradually brightening a light over a period of 30 minutes, where it
will reach it's peak brightness. I have the Basic stamp 2 starter
kit, a DS1302 real time clock, and a triac. The plan is that when the
clock hits a given time the microprocessor will start slowly
adjusting the firing angle to the triac which will step up the
voltage given to the light. My problem is that I am not sure how to
handle the programming. Any help on what commands I should use in
order to control the triac would be greatly appreciated.
Josh
jbw0592@n...
    > Thanks,
    > Josh
    > jbw0592@n...
    you will probably want to look at setting up an opto-daic to fire the
    triac, i have built dimmer packs before and the way i did it was to have
    the basic stamp give a value to an eight bit d/a chip, that fed the
    analog dimmer packs, the analog dimmers consisted of a compairitor with
    one input tied to a ramp circuit that was triggered and the ac zero
    crossing, the other would be the analog control signal, the compairitor
    fired an opto-diac which fired 4 trac's in parallel to get a channel
    rating of 2.4kw, if your interested i can did up the part numbers
    lw
