3-prong plug
The 3-prong adapter plug included in the "What's a Microprocessor" kit
seems to not be long enough on just one side. This adapter is used
to plug the servo to the Board of Education breadboard. The pins
seat just fine on the other end. Any suggestions?
I'm not familiar with the plug and cable, but could you have it reversed
(end-to-end) ??
Grasp the plastic portion of the 3-prong, and press the long end of the pins
down onto a hard surface. The plastic will slide on the prongs--use this to
center the plastic on the pins' length.
Daniel McGlothin
Original Message
From: tntmod@l... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Zgt_w2a1Cx8VBJIbkL6uK8maj281XoWXtLQUiwm_VExbyzEBXgufnd3-K4glJGaA7wDZDeYvYXffcFOw5A]tntmod@l...[/url
Sent: Thursday, October 05, 2000 11:28 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] 3-prong plug
the one on Robotics) that shows that you can just push the pins through the
center black strip so they are equal on both sides. I personally tried this
and it did work sort of. They are now equal on both sides, but when you try
to plug them into anything they just slip through the black center piece.
So they are pretty much useless to me. I've been meaning to replace them,
but haven't gotten around to it. For now, I have just plugged jumper wires
from the breadboard to the servo. I know it's a sloppy solution, but at
least I did get the servos to work.
Shawn
Original Message
From: tntmod@l... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aeE_pOyOJ2KhIrAyPR9KDZG72XpGViBSM0QgPx01N4s6Sf68uP072W1VDGeS4iEOCfyFSVpX5ZWZm9tkCA]tntmod@l...[/url
Sent: Thursday, October 05, 2000 9:28 PM
slide, actually I was afraid to try until someone suggested it. Tony
Original Message
To: <basicstamps@egroups.com>
Sent: Friday, October 06, 2000 10:05 AM
Subject: RE: [noparse][[/noparse]basicstamps] 3-prong plug
> What worked for me was to...
pins
to
> Regards,
> Daniel McGlothin
Original Message
> From: tntmod@l... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nsz5n7MSt8qkJyMOM0Cv-PpGW3NfmPyYiasomfuuqi9kIAXywFc9xw8zjXUEw4ADmih_gz3I7SrVU9_Y6FY]tntmod@l...[/url
