Troubleshooting
I'm having a problem communicating with my BS2 using the windows
editor. It can identify the Stamp is there but says to check power
supply. I have scoped and probed all voltages possible according to
the schematic and they appear to be there. I get a -5V reading on the
Sout pin. Is this correct? If I understand the manual correctly the
voltage should switch between -12V and +5V.
probably haven't gone to the extent you have, but you are receiving the same
message as me. I have been corresponding with parallax for a week about
this, but have not come to any conclusions. I will post the solution when I
get it.
Eric
Original Message
From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o3Q0KcSxtuc3h2gYGVtbw-fAYohVTf2G7qWK7ocQS0HxvxqtI1CiWIO6PbLVvK30JSvIiGvTR5uHquGkw32U]jdmiddle@t...[/url
Sent: Tuesday, October 03, 2000 11:24 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Troubleshooting
that would imply that your PC (a laptop maybe) is sending -5 instead of -12.
That shouldn't be a problem, since if the PC is generating -5 it should
expect -5.
A few things to think about.
1) Do you have either 5V connected to +5V (pin 22 If I recall) or 9V or more
connected to pin 24?
2) Do you have the ground pin grounded with a common ground to the power
supply and the computer (pin 5 of the DB9).
3) Do you have pins 6 & 7 shorted together? The Stamp editor uses this to
find the Stamp.
4) Is it possible you are using a "cross" cable that is reversing pins 2 and
3?
A few more questions:
a) What are you using? A BOE, a carrier board, an ASP-2, or something
homebrew?
b) What operating system?
c) What Stamp software (DOS, Windows, version?)
d) Are you using a BS2 or a BS2SX?
Al Williams
AWC
*Solderless Stamp Prototyping: http://www.al-williams.com/awce/asp2.htm
Original Message
> From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DoNjkerl2zUNtP-SPrZ0qDoF_pv22W2IS2STQy5WxhNK1ojxl7nbl4N6-zFPQDpjPaAUXcUiZ-JAaj2BpFc]jdmiddle@t...[/url
BS2 on a BOE in win98. I bought 3 at the time and 2 work, one doesn't.
Although it did appear to work for about 5 uploads. Don't ask me how, but
when it quit, it took out my comm port. I had to reinstall the hardware to
get it back. This has happened twice now. I don't seem to have any
problems with the DOS version of the editor.
Mark
>The Stamp routes power around from your serial port to get the - voltage.
So
of -12.
>expect -5.
more
>find the Stamp.
and
>3?
>homebrew?
>Regards,
>Al Williams
>AWC
Original Message
>> From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9TYIWEf6qLWdQ_hflToIgsgbvmyFQsgOMeqRvFklCr4nkYNi4dkwvJ2oeBOeKpDv3oBJbr4ZJpuoB6X5hkT7QfI]jdmiddle@t...[/url
Offhand I can tell you that the cable is a straight thru. I
understand
the basic concepts of RS-232 comms. I checked the voltages on the
actual cable itself and found my PC (running Win95) is putting out
-10V on the ATN and SIN lines but I get nothing on the pin that is
connected to SOUT until I attach it to the BS2 carrier board, which I
am using, and that's when I get the -5V. At the base of the PNP
transistor I am getting +5V from the micro-controller which I believe
is the PIC's TX line. Right now I am using the Windows editor. The
mystery to me is that all was running well last time I used it, now I
cannot even run the last program I entered after I hit the reset
button. I'm beginning to fear the worst! As for your other points I
will have to check them out later. Thanks again.
voltage. So
instead
of -12.
should
> expect -5.
9V
or more
power
this to
> find the Stamp.
pins 2 and
> 3?
something
> homebrew?
> Regards,
> Al Williams
> AWC
possible to control a video signal through the bs2? Something like turning
on and off or switching from one source to another or adding noise or
something like that.
Original Message
To: <basicstamps@egroups.com>
Sent: Wednesday, October 04, 2000 8:16 AM
Subject: RE: [noparse][[/noparse]basicstamps] Troubleshooting
> I have been having this exact problem myself. I don't have a probe, so I
same
I
> get it.
> Eric
Original Message
> From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Jod5cQSlwRvZGNziR8hWywfCDOWSLmOzj9oI2HckNf_qYM2PDbbX6tap9_n2mlPF5m7gCtkowOqeOQx-KA2wTJfRAA]jdmiddle@t...[/url
This is the first time I've responded to a question, so bear with me.
> I am really new to the BS functions so i also would like to ask if it is
I joined this group to learn about the BS2 because I was building a 16
channel surveillance camera switcher using the BS2, NCD's ASEL video
switcher, a Scott Edwards VFD module and a Decade Engineering BOB 2 On
Screen Display module. The BS2 controls all the major modules (listed above)
via serial control. The NCD crosspoint module is a little elaborate, and not
really all that appropriate for video (I know, I'm a professional video post
production engineer) but it's works just fine for this application. It would
have been cheaper to use MAXIM crosspoint chips and a little associated
cicutry. But the NCD modules were all built and ready to go, and had the
serial interface built in, so I went with those.
The project is basically finished now. If you would like further information
on the project, let me know.
Craig Latta
Original Message
> From: "Eric Schettler" <schettlee@p...>
> probe, so I
> same
> solution when
> I
> > get it.
> > Eric
Original Message
> > From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BtMS-iG3w82jNvf13nB1jOvsmWNu2qS2R28GtDvK3mH4Xqw9lIe2-uuMk5XxzgCoFZSi37Zg7Ka0ikB6BmL5E48T]jdmiddle@t...[/url
tell that a BS2 was there, but it couldn't communicate and to check
the power supply. i contacted Parallax and, while they gave me
several things to try, none of their suggestions fixed it. i was
getting worried that i had shorted the chip or something when i
realized that i was using an extention of .bs2 when i had a BS2sx.
changing the extention to .bsx made all the difference in the world.
hope this helps.
tom
the
