Troubleshooting — Parallax Forums
Troubleshooting
edited 2000-10-13 05:23 in General Discussion
I'm having a problem communicating with my BS2 using the windows
editor. It can identify the Stamp is there but says to check power
supply. I have scoped and probed all voltages possible according to
the schematic and they appear to be there. I get a -5V reading on the
Sout pin. Is this correct? If I understand the manual correctly the
voltage should switch between -12V and +5V.
    edited 2000-10-04 06:16
    I have been having this exact problem myself. I don't have a probe, so I
    probably haven't gone to the extent you have, but you are receiving the same
    message as me. I have been corresponding with parallax for a week about
    this, but have not come to any conclusions. I will post the solution when I
    get it.
    Eric
    From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o3Q0KcSxtuc3h2gYGVtbw-fAYohVTf2G7qWK7ocQS0HxvxqtI1CiWIO6PbLVvK30JSvIiGvTR5uHquGkw32U]jdmiddle@t...[/url
    Sent: Tuesday, October 03, 2000 11:24 PM
    To: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Troubleshooting
    edited 2000-10-04 13:53
    The Stamp routes power around from your serial port to get the - voltage. So
    that would imply that your PC (a laptop maybe) is sending -5 instead of -12.
    That shouldn't be a problem, since if the PC is generating -5 it should
    expect -5.
    A few things to think about.
    1) Do you have either 5V connected to +5V (pin 22 If I recall) or 9V or more
    connected to pin 24?
    2) Do you have the ground pin grounded with a common ground to the power
    supply and the computer (pin 5 of the DB9).
    3) Do you have pins 6 & 7 shorted together? The Stamp editor uses this to
    find the Stamp.
    4) Is it possible you are using a "cross" cable that is reversing pins 2 and
    3?
    A few more questions:
    a) What are you using? A BOE, a carrier board, an ASP-2, or something
    homebrew?
    b) What operating system?
    c) What Stamp software (DOS, Windows, version?)
    d) Are you using a BS2 or a BS2SX?
    Al Williams
    AWC
    *Solderless Stamp Prototyping: http://www.al-williams.com/awce/asp2.htm
    > From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DoNjkerl2zUNtP-SPrZ0qDoF_pv22W2IS2STQy5WxhNK1ojxl7nbl4N6-zFPQDpjPaAUXcUiZ-JAaj2BpFc]jdmiddle@t...[/url
    edited 2000-10-04 14:49
    Same problem here. Parallax says they never heard of it before. I'm using
    BS2 on a BOE in win98. I bought 3 at the time and 2 work, one doesn't.
    Although it did appear to work for about 5 uploads. Don't ask me how, but
    when it quit, it took out my comm port. I had to reinstall the hardware to
    get it back. This has happened twice now. I don't seem to have any
    problems with the DOS version of the editor.
    Mark
    So
    of -12.
    >expect -5.
    more
    >find the Stamp.
    and
    >3?
    >homebrew?
    >Regards,
    >Al Williams
    >AWC
    >> From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9TYIWEf6qLWdQ_hflToIgsgbvmyFQsgOMeqRvFklCr4nkYNi4dkwvJ2oeBOeKpDv3oBJbr4ZJpuoB6X5hkT7QfI]jdmiddle@t...[/url
    edited 2000-10-04 14:52
    Thanks for the input Al:
    Offhand I can tell you that the cable is a straight thru. I
    understand
    the basic concepts of RS-232 comms. I checked the voltages on the
    actual cable itself and found my PC (running Win95) is putting out
    -10V on the ATN and SIN lines but I get nothing on the pin that is
    connected to SOUT until I attach it to the BS2 carrier board, which I
    am using, and that's when I get the -5V. At the base of the PNP
    transistor I am getting +5V from the micro-controller which I believe
    is the PIC's TX line. Right now I am using the Windows editor. The
    mystery to me is that all was running well last time I used it, now I
    cannot even run the last program I entered after I hit the reset
    button. I'm beginning to fear the worst! As for your other points I
    will have to check them out later. Thanks again.
    voltage. So
    instead
    of -12.
    should
    > expect -5.
    9V
    or more
    power
    this to
    > find the Stamp.
    pins 2 and
    > 3?
    something
    > homebrew?
    > Regards,
    > Al Williams
    > AWC
    edited 2000-10-04 15:43
    I am really new to the BS functions so i also would like to ask if it is
    possible to control a video signal through the bs2? Something like turning
    on and off or switching from one source to another or adding noise or
    something like that.
    To: <basicstamps@egroups.com>
    Sent: Wednesday, October 04, 2000 8:16 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Troubleshooting
    same
    I
    > get it.
    > Eric
    > From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Jod5cQSlwRvZGNziR8hWywfCDOWSLmOzj9oI2HckNf_qYM2PDbbX6tap9_n2mlPF5m7gCtkowOqeOQx-KA2wTJfRAA]jdmiddle@t...[/url
    edited 2000-10-04 16:36
    Hi
    This is the first time I've responded to a question, so bear with me.
    I joined this group to learn about the BS2 because I was building a 16
    channel surveillance camera switcher using the BS2, NCD's ASEL video
    switcher, a Scott Edwards VFD module and a Decade Engineering BOB 2 On
    Screen Display module. The BS2 controls all the major modules (listed above)
    via serial control. The NCD crosspoint module is a little elaborate, and not
    really all that appropriate for video (I know, I'm a professional video post
    production engineer) but it's works just fine for this application. It would
    have been cheaper to use MAXIM crosspoint chips and a little associated
    cicutry. But the NCD modules were all built and ready to go, and had the
    serial interface built in, so I went with those.
    The project is basically finished now. If you would like further information
    on the project, let me know.
    Craig Latta
    > From: "Eric Schettler" <schettlee@p...>
    > probe, so I
    > same
    > solution when
    > I
    > > get it.
    > > Eric
    > > From: [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BtMS-iG3w82jNvf13nB1jOvsmWNu2qS2R28GtDvK3mH4Xqw9lIe2-uuMk5XxzgCoFZSi37Zg7Ka0ikB6BmL5E48T]jdmiddle@t...[/url
    i had a similar problem, getting a message that said that it could
    tell that a BS2 was there, but it couldn't communicate and to check
    the power supply. i contacted Parallax and, while they gave me
    several things to try, none of their suggestions fixed it. i was
    getting worried that i had shorted the chip or something when i
    realized that i was using an extention of .bs2 when i had a BS2sx.
    changing the extention to .bsx made all the difference in the world.
    hope this helps.
    tom
    the
