Digest Number 262
> OK Guys,
> I have installed two temp sensors and one IR tachometer on my gas
> turbine. They all work great. Thanks for your help. NOW, any ideas on
> pressure sensors???I need one for the combustion chamber, fuel
> pressure and oil pressure. Where do i get schematics and the sensors
> and the programs????
> Bill
Motorola, SenSyn, Lucas Novasensor, Measuement Specialties
Mike DeMetz sect. Michiana R/C Choppers
miked@t...
http://sites.netscape.net/mdemetz
> Bill
miked@t...
wrote:
> Mike, any sensor in particular???? Prices, pin layout
schematics???? Bill
You were looking for monitoring a turbine? You'll will probably need
the threaded stainless steel type($$$). Digi-Key carries some.
Motorola and SenSym have app notes at their WEB sites.
All I've seen are Wein bridge configuration where you supply a
excitation voltage and get a mV output proportional to pressure. They
come in 3 configurations, plain sensor which needs temperature
compensation, with compensation and signal conditioned(0-5V out). The
3 package types are absolute(referenced to a vacum), gauge(referenced
to the atmosphere) and differental(referenced to a second port).
