remote control using holtek encoder??
Hello,
I am trying to put together a schematic
of a remote control using a holtek ht-12e,
and between the osc1 and osc2 pins, this
schematic calls for a 750k resister?
Does this have to be 750k, or will perhaps
a 1meg work, or some other large value?
What's going on when you see this sort of thing,
'osc1' and 'osc2', This is an onboard oscillator right?
to use a 62K with the HT-12D decoder IC.
The recommended oscillator resistor values are:
HT-12E 750K when used with the HT-12D 33K or
HT-12E 1.1M when used with the HT-12D 62K
The osc1 is the oscillator input-pin. Osc2 is the oscillator
output-pin. The oscillator resistors can be %5 tolerance,
and matching the recommended values as closely as possible
is a good idea for optimal performance.
If you're far off, you'll throw the encoder/decoder pair out of
synch.
Bruce
webmaster@r...
http://www.rentron.com
| Thanks
