Ir support
Count is good for up to 125khz I tried the code below (someone tell me
if it will really work) using 16 divided by 10 for the period in
milliseconds can this really work or will it revert to 1
t var word
count 1, 16/10,t
Kerry Barlow wrote:
> Bill: I cannot help with your tach reading,people should know you are
> talking about 40,000-60,000 rpm though correct?
> I am an aircraft mechanic and would be interested in hearing some details
> of your turbine engine,just out of curiosity.If you would wish to contact me
> off list I would appreciate this
> Kerry
> admin@m...
> At 01:17 AM 9/26/2000 -0000, you wrote:
> >Hi everyone. I like how you guys help eachother out. It's cool. Maybe
> >you can help me out as well.
> > I have created small gas turbine. I need a tachometer on it so i
> >have decided to create an IR tacho. I will send out an IR source,
> >relect it off of the turbine shaft and then the signal will be picked
> >up by a IR receiver or by a photodiode. The shaft will be painted
> >half black and half white so that as the shaft rotates only one
> >signal will be reflected off the rotating shaft. (One per
> >revolution.) Question is im really not sure how to progress. I have
> >decided to use a BS2 as the way to transfer data to a PC. I have set
> >up temp sensors and inlet/exhaust air temp sensors and a pressure
> >sensor but for some reason i cant figure out how to get to where i
> >need to be on this tacho. Any suggestions schemats and BS programs
> >would be highly appreciated. thanks Bill
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
> [url=Http://mntnweb.com]Http://mntnweb.com[/url]
> Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
> CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
> --So you think you need more memory... the LEM went to the moon on 16K,how
> much do you REALLY need?
t var word
count 1, 16/10,t
> Kerry
> admin@m...
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
Kerry
admin@m...
Sincerely
Kerry
Admin@M...
WWW server hosting
myself and i worked on turbine engines. F-15 motors. Prattand whitney f-100
pw100's to be precise.
the IR source and destination clear of debris or buildup?
-erik
Original Message
From: LarryGaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mAyyHKldvS4aFr7VrGTSmD1zmPn8vUihpwO9toW4L2V30Cdgm0N4yRmbXJ7GnZHivKs7qlANEKbaTdUb]lgaminde@t...[/url
Sent: Sunday, September 24, 2000 7:29 AM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] IR SUPPORT
t var word
count 1, 16/10,t
me
> Kerry
> admin@m...
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
16K,how
You may find this of interest:
http://www.emesystems.com/BS2misc.htm#directional
It's one of many tutorials with BS-2 examples on the eme systems website.
Tracey monitors this list as well.
Hope that helps.
> I have
out. First I'm going to move the IR trans. and photoresistor to a suitable
location and not right next to the compressor. I will probably use fiber
optic cable to move the light from the compressor to the trans and receiver.
They will will be installed in the compressor intake which has to be clean
from dust and debris. I will fix them in some kind of housing that can be
removed and cleaned when ever necessary.
information? Me a lot, but one thing at a time!
Original Message
To: <basicstamps@egroups.com>
Sent: Tuesday, September 26, 2000 9:15 AM
me
> Kerry
> admin@m...
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
16K,how
-erik
Original Message
From: Mr. and Mrs. Fizer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TmAwlmISKrIPv1x1uivroa7mFcXTxEWcyzKi7Uofl-nFqkI1eChtFtBNo6Pmvcoa0HQHkwT0_ow]voyagermb@h...[/url
Sent: Tuesday, September 26, 2000 1:45 PM
Hi Erik. Thanks for the question. Well I do have a couple of things figured
>t var word
>count 1, 16/10,t
No, the 16/10 does revert to 1.
t var word
count 1,1000,t
would return a value of t from 40000 to 60000 though.
even a few pictures and some technical specs to an acceptable binary forum or
newsgroup.
Allan
Carl McIver wrote:
> I too am interested. Perhaps you could tease us all with some more
Original Message
> From: Kerry Barlow <admin@m...>
> me
> > Kerry
> > admin@m...
> > Sincerely
> > Kerry
> > Admin@M...
> > WWW server hosting
> 16K,how
too [noparse]:)[/noparse]
How about posting it BB? :P
Stamp on!
Aunt_Bea
>From: Bruce Bates <bvbates@u...>
>Reply-To: basicstamps@egroups.com
>Date: Tue, 26 Sep 2000 16:02:08 -0400
>Hope that helps.
> > I have
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
sure.
Aunt_Bea (ASMEL&S, CFII, BS/MS A&AE)
>Date: Tue, 26 Sep 2000 12:15:08 -0400
>me
>Kerry
>admin@m...
>Sincerely
>Kerry
>Admin@M...
>WWW server hosting
Original Message
Sent: Thursday, September 28, 2000 11:30 AM
> HI!!!!!
