Ir support — Parallax Forums
Ir support
edited 2000-09-28 17:54 in General Discussion
Count is good for up to 125khz I tried the code below (someone tell me
if it will really work) using 16 divided by 10 for the period in
milliseconds can this really work or will it revert to 1
t var word
count 1, 16/10,t
Kerry Barlow wrote:
> Bill: I cannot help with your tach reading,people should know you are
> talking about 40,000-60,000 rpm though correct?
> I am an aircraft mechanic and would be interested in hearing some details
> of your turbine engine,just out of curiosity.If you would wish to contact me
> off list I would appreciate this
> Kerry
> admin@m...
> At 01:17 AM 9/26/2000 -0000, you wrote:
> >Hi everyone. I like how you guys help eachother out. It's cool. Maybe
> >you can help me out as well.
> > I have created small gas turbine. I need a tachometer on it so i
> >have decided to create an IR tacho. I will send out an IR source,
> >relect it off of the turbine shaft and then the signal will be picked
> >up by a IR receiver or by a photodiode. The shaft will be painted
> >half black and half white so that as the shaft rotates only one
> >signal will be reflected off the rotating shaft. (One per
> >revolution.) Question is im really not sure how to progress. I have
> >decided to use a BS2 as the way to transfer data to a PC. I have set
> >up temp sensors and inlet/exhaust air temp sensors and a pressure
> >sensor but for some reason i cant figure out how to get to where i
> >need to be on this tacho. Any suggestions schemats and BS programs
> >would be highly appreciated. thanks Bill
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
> [url=Http://mntnweb.com]Http://mntnweb.com[/url]
> Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
> CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
> --So you think you need more memory... the LEM went to the moon on 16K,how
> much do you REALLY need?
    edited 2000-09-26 02:17
    edited 2000-09-26 17:15
    Kerry
    admin@m...
    Sincerely
    Kerry
    Admin@M...
    WWW server hosting
    edited 2000-09-26 17:23
    actually im talking about 100,000rpm. I used to be an aircraft mechanic
    myself and i worked on turbine engines. F-15 motors. Prattand whitney f-100
    pw100's to be precise.
    edited 2000-09-26 20:52
    Sounds like a cool project! Not to be a wet towel, how are you going to keep
    the IR source and destination clear of debris or buildup?
    -erik
    From: LarryGaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mAyyHKldvS4aFr7VrGTSmD1zmPn8vUihpwO9toW4L2V30Cdgm0N4yRmbXJ7GnZHivKs7qlANEKbaTdUb]lgaminde@t...[/url
    Sent: Sunday, September 24, 2000 7:29 AM
    To: basicstamps@egroups.com
    Subject: Re: [noparse][[/noparse]basicstamps] IR SUPPORT
    t var word
    count 1, 16/10,t
    me
    > Kerry
    > admin@m...
    > Sincerely
    > Kerry
    > Admin@M...
    > WWW server hosting
    16K,how
    edited 2000-09-26 21:02
    You may find this of interest:
    http://www.emesystems.com/BS2misc.htm#directional
    It's one of many tutorials with BS-2 examples on the eme systems website.
    Tracey monitors this list as well.
    Hope that helps.
    > I have
    edited 2000-09-26 21:45
    Hi Erik. Thanks for the question. Well I do have a couple of things figured
    out. First I'm going to move the IR trans. and photoresistor to a suitable
    location and not right next to the compressor. I will probably use fiber
    optic cable to move the light from the compressor to the trans and receiver.
    They will will be installed in the compressor intake which has to be clean
    from dust and debris. I will fix them in some kind of housing that can be
    removed and cleaned when ever necessary.
    edited 2000-09-27 03:51
    I too am interested. Perhaps you could tease us all with some more
    information? Me a lot, but one thing at a time!
    To: <basicstamps@egroups.com>
    Sent: Tuesday, September 26, 2000 9:15 AM
    me
    > Kerry
    > admin@m...
    > Sincerely
    > Kerry
    > Admin@M...
    > WWW server hosting
    16K,how
    edited 2000-09-27 09:29
    Best of luck with your project! Look forward to progress posts.
    -erik
    From: Mr. and Mrs. Fizer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TmAwlmISKrIPv1x1uivroa7mFcXTxEWcyzKi7Uofl-nFqkI1eChtFtBNo6Pmvcoa0HQHkwT0_ow]voyagermb@h...[/url
    Sent: Tuesday, September 26, 2000 1:45 PM
    edited 2000-09-27 16:49
    >t var word
    >count 1, 16/10,t
    No, the 16/10 does revert to 1.
    t var word
    count 1,1000,t
    would return a value of t from 40000 to 60000 though.
    edited 2000-09-27 23:46
    Do you have plans to post your wickedly cool project to a web site? Or maybe
    even a few pictures and some technical specs to an acceptable binary forum or
    newsgroup.
    Allan
    > From: Kerry Barlow <admin@m...>
    > me
    > > Kerry
    > > admin@m...
    > > Sincerely
    > > Kerry
    > > Admin@M...
    > > WWW server hosting
    > 16K,how
    edited 2000-09-28 11:09
    I for one would pay $20 for a list of all the great links Bruce has access
    too [noparse]:)[/noparse]
    How about posting it BB? :P
    Stamp on!
    Aunt_Bea
    >From: Bruce Bates <bvbates@u...>
    >Reply-To: basicstamps@egroups.com
    >Date: Tue, 26 Sep 2000 16:02:08 -0400
    >Hope that helps.
    > > I have
    _________________________________________________________________________
    Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
    Share information about yourself, create your own public profile at
    http://profiles.msn.com.
    edited 2000-09-28 11:14
    Forget the off-list discussion. I'm interested...as well as others, I'm
    sure.
    Aunt_Bea (ASMEL&S, CFII, BS/MS A&AE)
    >Date: Tue, 26 Sep 2000 12:15:08 -0400
    >me
    >Kerry
    >admin@m...
    >Sincerely
    >Kerry
    >Admin@M...
    >WWW server hosting
    edited 2000-09-28 17:30
    HI!!!!!
    Hi!!!
    Sent: Thursday, September 28, 2000 11:30 AM
    > HI!!!!!
