0-10V output
How about a chip that provides a 0-10V output from stamp serial out
that can be scaled as needed? Has anyone ever used anything like
this, or have any Ideas?
0-5V. A PAK-V will do the same thing, but 8 channels at a time while the
Stamp program is still running.
It is pretty easy to make a x2 op-amp buffer that converts 0-5 to 0-10. The
only issue is that with 8 bits of resolution, you get 5/256 = 19.5mV/step.
If you x2 you get 10/256=39.1mV/step.
The PAK-8 can do PWM (with a little math) in 16 bit steps. So then you get
something like 5/65536 or 76uV/step in theory (x2 would be about
152uV/step). However, at that small level, you may be dominated by system
noise any way.
Al Williams
AWC
* Expand your Stamp I/O with the PAK-III or PAK-IV:
http://www.al-williams.com/awce/pak3.htm
Original Message
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DqWzwJO7sEGJh7a9C8rbLI_qeCKUpIaaOS6GrMC2dBS-MwZosjs-Vrv0n9Yd5qnPzHgYm9Ey4gUzfi6RGdSHgV06lvQyfbNy]chris@a...[/url
> Sent: Friday, July 14, 2000 2:34 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] 0-10V output
an operational amplifier ? )
ACJacques
ACJacques
