PS trouble?
I have no power problems when running BS2's on carrier boards when
using a 9VDC input to the carrier's supply. When I use a 12VDC
supply, the stamp warms up and I lose serial communication - "device
not found" type error. After they cool off, and I reduce the input
voltage back to 9 or less, all is well.
What are the possibilities?
Thanks in advance,
Chris
Thanks in advance,
Chris
It sounds like you may have regulator problems. Make sure your power supply
is connected to the regulator *INPUT*, not the +5 (Vcc) terminal. If your
connection is correct, maybe the regulator is bad. Put a voltmeter on the
regulator output or stamp Vcc pin; it should maintain 5V for 9 or 12 volts
in. The Stamp should not warm up noticeably.
Good luck,
Ray McArthur
Original Message
To: <basicstamps@egroups.com>
Sent: Monday, June 05, 2000 9:39 PM
Subject: [noparse][[/noparse]basicstamps] PS trouble?
