Stamp wish list
Adding to the wish list for a modern stamp
1) real time clock
2) interrupts
3) more memory
4) larger variable space (the stamp IIsx does NOT fit the bill for these)
5) Dallas 1 wire compatibilty
6) natch,you can never have to much speed
7) PLEASE STAY WITH BASIC as a programming language
I dont see the small footprint of a stamp as a real selling pt.Possibly
increasing its overall size by a small amount to add many more features
would not be to bad.I cant imagine anyone even in industry actually needing
such a tiny footprint,not after they use the 16 IO lines etc etc etc
increasing overall circuit size anyhow.
Sincerely
Kerry
Admin@M...
WWW server hosting
[url=Http://mntnweb.com]Http://mntnweb.com[/url]
Binghamton online Webcam [url=Http://MntnWeb.Com/bing.htm]Http://MntnWeb.Com/bing.htm[/url]
CHRISTMAS Web Page [url=Http://mntnweb.com/xmas.htm]Http://mntnweb.com/xmas.htm[/url]
1) real time clock
2) interrupts
3) more memory
Sincerely
Kerry
Admin@M...
WWW server hosting
100 Mhz, 40(36) I/O ports, 256 bytes of memory, 4K x 12 EEPROM,
multiple timers. Except for somewhat limited memory, with the right
on-board software, it should blow the doors off the existing "chips".
Add a fast external 32K (or more) EEPROM, and you have a pretty heavy
duty "stamp" (well, maybe it's a little larger). Put it on a 40 pin
x .6 inch board so it still fits into a standard socket.
Other wants:
Multiple, Real RS232/RS485 communication (full duplex, running
simultaneously with other functions)
Multi-tasking (a problem with limited memory, but even one additional
task would be nice.)
Compiler with real functions and subroutines (PLEASE!)
Option to have compiled code loaded into memory instead of (or along
with) the interpreter - now you have some really serious speed
capabilities. There's only 4K of memory, but you could modularize the
interpreter so only the parts you use are loaded (does anyone use all
100+ PBASIC functions?), leaving the rest of the space for user code.
Chuck Davis
Oak Tree Systems LLC
Aside from some of what has already been mentioned, perhaps an
addition of new commands might be in order. Software is easier to
change/develop, sometimes, than hardware.
Just two examples:
I often find I'd like to use RCtime with a single command, where
bringing pins high and low, with pauses, is clumsy.
A possibility: define an rctime comparator. With pin 3, rc3 would
return a 1 if the rctime value is greater than a predetermined value, and
0 if not. I can simply define this threshold, rc3 xxxx 130, then use rc3
in any branch command, etc. All normal rctime functions are automatically
incorporated into this call.
Also, real if-then statments would come well. That is, not having
to branch on a condition; actual if-then-else-end are a need of many, I
believe.
Thanks for your time, have a nice afternoon.
Paul
Argh! Stamp's basic implementation is an irrevocably crippled
implementation of an irrevocably crippled language! Anyone with any kind
of software background who has used the stamp knows this. I had thought
about dumping the stamp and using a PIC, just because I thought that pic
assembler might give me more control over what I'm doing.
Case in point - as far as I know you can't do the following
if (pin0 is high)
function1();
else
function2();
This is a really basic control structure, and as far as I can tell, you
can't do it in pbasic. I'd love to see a stamp running C, C++, pascal,
ADA, perl, prolog, lisp, cobol, eiffel, python,php4, or a better version
of basic.
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
I use the stamp *because* it is BASIC. If I wanted to develop in C or asm I
would use a PIC (and do, sometimes). The BASIC stamp lets me get my
prototypes up and running *now*, not later.
Anyways, to do what you want in PBASIC use the following code snippet:
if in0=1 then goto function1
function2:
(function 2 code)
goto endsnippet
function1:
(function1 code)
endsnippet:
It's not as clean as some other BASICs, but it runs in a small amount of
space, and it gets the job done.
My $.02 CDN
Kyle
R. Kyle Schmidt
Control System Specialist
Messier-Dowty Inc. "The Landing Gear Company"
kyle.schmidt@m...
Original Message
> From: Sean T. Lamont .lost. [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yP5TVoTbiPr5dGPsLwcRw_ErInl8RCr9cZIOy7C_mfmo8tQUDtCgoWwr0n0fIw5ZyZTBP1BHF33XDWxUGYk]lamont@a...[/url
> Sent: Wednesday, May 03, 2000 3:28 PM
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Stamp wish list
> Mostly I agree with these statements, but...
> if (pin0 is high)
> function1();
> else
> function2();
> of basic.
> I am sure you will be bombarded with answers to this, but here goes.
There are way easier prototyping languages. I spend half my time with
parallax basic trying to work around the limitations of the language.
> function2:
> (function 2 code)
> goto endsnippet
> function1:
> (function1 code)
You missed my point. I didn't mean "is it possible to write a program
which has the same functionality as X", I was speaking about a basic
logical program flow. What if function1() and function2() are subroutines?
It's _not_ possible. Not to mention the fact that for even a modest
project, the spaghetti code factor goes through the roof. I could do this
on the Commodore vic-20 in 1983, and to be fair, the stamp is a more
powerful computer. They should have at least gotten the basic right. One
very simple modification which would go a long way would be to allow gosub
inside a conditional. This is just a sloppy oversight.
program flow. But what prototyping languages are out there that will run in
the given space?
The if structure is not intuitive, and I have had some of my employees make
mistakes with it. But, you can put a gosub in where the function code would
go. So, you are looking at five lines of code instead of three. It's not a
big deal.
I would like to see a case structure. I would also like to be able to
program the stamp in LabVIEW, which is my favourite language, but since that
is a little unreasonable, I don't expect to be able to do it. I choose a
certain tool for a certain job.
Now, if you are wondering whether Parallax could change PBASIC to permit
better handling of conditional branching, you would have to ask them.
In addition, I would contend that the VIC20 was a more powerful computer
than the stamp. For one (very important thing), it had far more variable
space. This alone made the implementation of complex branching possible.
Kyle
R. Kyle Schmidt
kyle.schmidt@m...
Original Message
> From: Sean T. Lamont .lost. [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QhgxEFEAhl7wKqP9cEa5twkCRKuCHI6A_sRWP4vIEZHeiXtg4wClXNLVzXYvHrIqjNae-rU-9i8XGOb5XN8PLg]lamont@a...[/url
> Sent: Wednesday, May 03, 2000 3:44 PM
> To: 'basicstamps@egroups.com'
> Subject: RE: [noparse][[/noparse]basicstamps] Stamp wish list
> asm I
> > function2:
> > (function 2 code)
> > goto endsnippet
> > function1:
> > (function1 code)
Well, here goes my list (not in any particular order of priority)
Multitasking capability
Internal A/D converter
True If - Then - Else
Interupt Capability
SPI Communications
I2C Communications
Proper RS232 Communications (get rid of all those bloody timing delays
between individual bytes sent. i.e. able to communicate with non stamp
products)
More than 2K Programming Space
True Math Rules (i.e. follow the standard way of solving problems, not this
strict left to right hand rule)
Floating Point Capability
Local Variables in Subroutines
Multi-Dimensional Arrays
The ability to send more than 8 characters out at one time in a serial
command.
Source more than 100 ma?
Higher Math Functions, like sin, cos, tan, abs, log, ln, fix, sqrt, power,
etc.
Not having to deal with bank switching.
Ability to mix Assembly with Basic
Ability to be programmed with Windows NT4.0 that has a 32bit file system.
Most improtantly, a compiled language, not an interpreted one. This way,
different microprocessers can be programmed. I am not that particular
between the PIC, SX, Atmel, or even the HC11. As long as it works.
writes:
> I dont see the small footprint of a stamp as a real selling point.
Not so! A very big selling point of a recent product I developed is its
small size. Using the Stamp 2 made it easy for me to develop the software
and to keep the product size in check. I be thrilled with a Stamp 1 with
more memory.
-- Jon Williams
-- Dallas, TX
to the PIC, try the PicBasic Compiler. It has real IF, THEN, ELSE
commands.
We carry the PicBasic Pro, and PicBasic Compilers at:
http://www.rentron.com/PicBasic.htm
If you're wanting to get the most our of your BASIC Stamp, grab a copy
of Al Williams book "Microcontroller Projects with BASIC Stamps", or
Scott Edwards "Programming and Customizing the BASIC Stamp".
Bruce Reynolds
Original Message
To: <basicstamps@egroups.com>
Sent: Wednesday, May 03, 2000 1:27 PM
> if (pin0 is high)
> function1();
> else
> function2();
> of basic.
www.basicx.com
It has a lot of the features that you all are asking for in your wish list
postings. There is a somewhat active maillist on egroups as well - called
(DUH) basicx which you can get in digest form - by-the-way
Just my 2 cents
Vic
__________________________________________
Victor Fraenckel vfraenc1@n...
Home of the WindReader Electronic Theodolite
Read the WIND
> I must agree that the given syntax makes it sometimes difficult to trace
> the given space?
A stripped down version of C would probably be appropriate - IE, no
stdlib, stdin, math libraries. Limited debugging libraries.
> big deal.
You still cannot, as far as I know, branch to a subroutine on conditional.
Also, as far as I know, you cannot define parametrized subroutines. This
is a simple stack operation and some lexical parsing, it would add much to
parallax's basic and probably take a small number of bytes of assembly to
implement. I expect most of it could be done in the editor. Oh, that would
e another thing would be c-style CPP that could handle includes and macros
- this could be done entirely in the editor.
Depends on what perspective you take. Then again, the SX is about 50x
faster.
Frankly I hate it! It takes a LEAST twice as long to write decent code, if
you aren't fed up by then. I must confess that I've moved to the OOPIC. Wow!
What a breath of fresh air. *real* subroutines, and if-else! Maybe Parallax
should come out with a Turbo Stamp. [noparse]:)[/noparse] Programmable in a *real* programming
language. I want more I/O and A/D conversion, multitasking, and event driven
interrupts.
-William
www.GoRobotics.net
Original Message
Sent: Wednesday, May 03, 2000 2:04 PM
Subject: [noparse][[/noparse]basicstamps] Stamp wish list
> 1) real time clock
> 2) interrupts
> 3) more memory
needing
> Sincerely
> Kerry
> Admin@M...
> WWW server hosting
-William
www.GoRobotics.net
Original Message
Sent: Wednesday, May 03, 2000 3:27 PM
> if (pin0 is high)
> function1();
> else
> function2();
> of basic.
competitors, I'll suggest another (only at the risk of getting blasted,
of course).
Check out: www.rabbitsemiconductor.com
They advertise:4 serial ports, floating point math, C programmable,
interrupts, battery backed RTC, WD timer, built in timers, 40+ I/O pins.
Plus they offer an evaluation board and kit for $100 that includes a
built in ADC and DAC.
> Check out the BX24 from NetMedia:
> www.basicx.com
list postings. There is a
> somewhat active maillist on egroups as well - called (DUH) basicx which
> form...
wouldn't be the Basic Stamp. The Stamp is popular, not because it can do
all things for all people, but because it can do LOTS of things very simply.
It can do it with minimum development time and it can do them in a way
that
is very easy to debug. When the OOPIC or BX-24 go out to lunch, its very
hard to figure it out because the libraries are hidden and you are still
modifying them, you just can't tell what you just did in many cases.
The other products are no doubt good for something, but in most cases,
they just won't replace the Stamp's ease of use, ease of programming and
just plain reliability. A VW beetle isn't a Porche, but its more reliable
than a Porche...
IMO, YMMV,
DLC
William Cox wrote:
> Well folks, I have to enter the debate on the JUST SAY NO TO PBASIC side.
> interrupts.
> -William
> www.GoRobotics.net
Original Message
> From: Kerry Barlow <admin@m...>
> > 1) real time clock
> > 2) interrupts
> > 3) more memory
> needing
> > Sincerely
> > Kerry
> > Admin@M...
> > WWW server hosting
Dennis Clark http://www.verinet.com/~dlc
dlc@v...
if you ask me. They need to give you more control structure, ie. ..
If... Elseif... else... End if rather than just If... Goto. to get
rid of the dang GOTO's.
Also, adding fuctions and subroutines that could accept arguments is
a must. If you ask me though, there's nothing wrong with basic. If
Parallax adopted a version with similar structure to even QBasic, I'd
have no complaints. It's much easier than learning assembly if your
new to electronics and programming.
-Chris
--- In basicstamps@egroups.com, "Sean T. Lamont .lost."
kind
thought
that pic
> if (pin0 is high)
> function1();
> else
> function2();
you
pascal,
version
> of basic.
(ServNet)
Bremerton
Simpson
> than a Porche...
I don't want to start a flame war, but I maintain that most people who
believe that basic in general, and pbasic in specific, is easier to
program than more structured languages haven't spent much time with
anything else. If anyone with a software engineering or
large-scale development background chooses to step up and say yes, pbasic
is better for what it's meant to do than other languages, I'll gladly
reconsider my position.
For as vitriolically as I've been trouncing basic, I agree with this 99%.
Of course, then it approaches a more structured language like pascal or C,
which is exactly what I've been saying.
lamont@a... writes:
Too late.....
lamont@a... writes:
> If anyone with a software engineering or large-scale development background
> chooses to step up and say yes, pbasic is better for what it's meant to do
than
> other languages, I'll gladly reconsider my position.
"Better" is a relative term and only meaningful in the eye of the beholder.
PBASIC is what it is -- take it or leave it. Yes, it's a bit quirky when
compared to PC-oriented versions of BASIC, but we're not doing PC-type
projects here, we're doing small-scale embedded control.
doing with a BASIC stamp that would require so many features?
> etc.
OK, I'll take that challenge. I've been in the software/computer
industry for about 19 years. Including working on embedded software
on disk drives, tape drives, mother boards and manufacturing floor machines.
I've worked on OS system code, processor simulation packages, HTML, web,
some database and even a few GUI packages.
For fast turnaround embedded controllers, the Stamp is the best thing
I have seen yet (I've worked with stuff from the venerable 8748 to the
not-so-venerable 6809 (which I hated)). Whoa, embedded emphasis, I hate
LISP.
How depressing, it appears that I _have_ been around the block a few
times.
I don't want to invalidate your opinion, but mine seems to be vastly
different. Stamps are damn simple - at times frustrating for those of
us used to more lush languages, but heck, for simple embedded stuff, I'll
place the Stamp up against any of the options out there in a contest of
development and debugging time. It could be that because I have a LOT of
time in on PICs in general, I don't find PBASIC quite as baffling as some
might.
IMO, YMMV,
DLC
> > than a Porche...
dlc@v...
Of course it is, and what I said was "Better" in the eye of someone who
actually knows anything about computer languages, not better in the eye of
someone who may know a ton about small-scale embedded control but hasn't
ever written a substantial program in their life. IMO, the former group
are better suited to judge it against other programming languages, even
for what it's designed for. And I firmly place myself in the former group
- my electrical design skills are rudimentary at best, and I have
substantial background in large-scale object-oriented databases. So at the
very least you see my bias.
> might.
Thanks for your opinions. Though what I'm hearing from you is "Stamps are
better than other microcontroller programming environments", which I can
certainly believe. But what I'm hearing from other list members with less
development experience than yourself is "pbasic's simplicity as an
embedded language is better than complicating things which such "high
level" constructs as modern control flow.', which I patently disagree
with, and I expect probably stems from a lack of knowledge of what modern
control flow is, and why it may be good.
> Sean,
[noparse][[/noparse]snip]
I would like to retract everything after this line - I sounded like
a pompous old fart. Since I'm only 40, I would like it to pick up like so:
for a little while. I think the Stamps are the best thing since sliced
bread for simple embedded projects. Yeah, uh-huh, yup.
DLC
dlc@v...
I've programmed in everything from C to java, to ASM, but before all that, I
played with the stamp. I found it really nice with a limited background to be
able to create something useful.
I guess the only issue is now that I know more, I'm ready for more complicated
programming methods, but the basic stamp stops about half-way up the
microcontroller learning curve.
it seems like half the messages on this list are from people who can't get their
computer to talk to their stamp, and the other half are from people looking for
or suggesting ways to get around the language's peculiarities.
I like the concept, but it needs more functionality.
Jason Lavoie
makes doing anything worth while with it just plain difficult.
-William
Original Message
Sent: Wednesday, May 03, 2000 8:04 PM
> Hmm, and I'll enter on the other side. If it wasn't in Basic, then it
simply.
> that
> than a Porche...
> IMO, YMMV,
> DLC
side.
if
Wow!
Parallax
programming
driven
> > interrupts.
> > -William
> > www.GoRobotics.net
Original Message
> > > 1) real time clock
> > > 2) interrupts
> > > 3) more memory
these)
pt.Possibly
features
> > needing
> > > Sincerely
> > > Kerry
> > > Admin@M...
> > > WWW server hosting
> dlc@v...
It allows mechanical engineers with little electrical/electronics/software
background beyond Ohm's Law, to use the Stamp to control purely
mechanical processes electronically. Rather than having to accept
incomprehensible solutions from electronics/software people who
who do not know, and are not even interested in finding out, what a
mechanical advantage is!
Original Message
Sent: Wednesday, May 03, 2000 8:10 PM
reliable
> > than a Porche...
_____________________________________________
NetZero - Defenders of the Free World
Click here for FREE Internet Access and Email
http://www.netzero.net/download/index.html
is today and ya'll might buy it in the future.... Except, with all the
changes ya'll propose, it will cost $347.18. Close? (flame suit on)
Dan
Original Message
From: William Cox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dlkriaPShgqwboCdjPfIercqlk8WWlw3KcyfysdSb3-SI3p7QNQjUxb9KcGuxLVt-siupUUCWcr1qMD16Tbsz-0]william@c...[/url
Sent: Thursday, May 04, 2000 5:35 AM
But I think it would be MORE EASIER without the pBasic language. I think it
-William
Original Message
simply.
> that
> than a Porche...
> IMO, YMMV,
> DLC
side.
if
Wow!
Parallax
programming
driven
> > interrupts.
> > -William
> > www.GoRobotics.net
Original Message
> > > 1) real time clock
> > > 2) interrupts
> > > 3) more memory
these)
pt.Possibly
features
> > needing
> > > Sincerely
> > > Kerry
> > > Admin@M...
> > > WWW server hosting
> dlc@v...
language. If real subroutines and If-Else were added I would be completely
satisfied. I mean, they aren't *that* hard to figure out. As for all the
other "improvements" we've been suggesting, I'm sure we all realize that
they will never happen. Right?
-William
Original Message
Sent: Thursday, May 04, 2000 12:02 PM
> May I give a synopsis? Change everything that made the basicstamp what it
> Dan
Original Message
> From: William Cox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XeyJ9OAoJ8TZjgcHbIWyXdE-AnkG3PnsV8VQH2E79dXoHYvPN4ls8NV2ZdqtoHGknyZxnRiKW9icnlXkxfAS]william@c...[/url
it
> -William
Original Message
> From: Dennis Clark <dlc@v...>
do
> simply.
> > that
very
reliable
> > than a Porche...
> > IMO, YMMV,
> > DLC
> side.
code,
> if
OOPIC.
> Wow!
> Parallax
> programming
> driven
> > > interrupts.
> > > -William
> > > www.GoRobotics.net
Original Message
> > > > 1) real time clock
> > > > 2) interrupts
> > > > 3) more memory
> these)
> pt.Possibly
> features
> > > needing
> > > > Sincerely
> > > > Kerry
> > > > Admin@M...
> > > > WWW server hosting
> > dlc@v...
