Eeprom error — Parallax Forums
Eeprom error
ArchiverArchiver Posts: 46,084
edited 2003-04-15 13:56 in General Discussion
my Stamp has a problem. it works 100% on my tower computer but on my
laptop computer when i try to run the program a sign comes up and
says "ERROR: EEPROM verify failed". do you think i need a new EEPROM
chip? i already know that it is not the batt or the cable or the
software. send back ideas.
  • ArchiverArchiver Posts: 46,084
    edited 2000-05-02 04:33
    What kind of Stamp?
    Dennis Clark http://www.verinet.com/~dlc
    dlc@v...
    edited 2000-05-02 04:46
    it is a BASIC Stamp stater kit version 1.0
    edited 2000-05-02 04:59
    Your problem has nothing to do with your stamp. Many
    laptops won't work with the Stamp I's parallel port
    programming setup. Mine won't either.
    dlc@v...
    edited 2000-05-02 05:42
    I've also encountered problems with Desktop / Mini-tower systems. The only
    commonality was they desktops had multi-media capabilities.
    -r
    Original Message
    From: Dennis Clark [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iTu9fGN8xE3nmdF_WhZGWIfp0k7kQxWpMj1ebSC-lBZqvDu7o4nmMk0svn1-8fsAOxTjS9HV7zb5]dlc@v...[/url
    Sent: Monday, May 01, 2000 8:59 PM
    To: basicstamps@egroups.com
    Subject: Re: [noparse][[/noparse]basicstamps] RE: RE: EEPROM ERROR
    dlc@v...
    edited 2000-05-02 20:48
    if it doesn't work on laptops then why does it say "EEPROM error" and
    not "handware not found"
    edited 2000-05-02 21:28
    I'm not sure if you are talking about the stamp program for the basic
    stamp II, but I have found that both the dos and windows versions work
    fine on my Inspiron laptop (laptop sux but software works good<G>).
    I did have a problem where I kept getting a message about the basic stamp
    not responding, that parallax tech support diagnosed as a damaged stamp.
    After getting a new stamp, getting the same message, I started trying
    other things. Turns out that the perfectly-good-looking, nearly brand
    new, serial cable was defective. Stole an old cable off of a decrepit
    modem in my junk box, got a 9-to25 adapter, and veeola, both stamps
    worked fine.
    but as for the laptop, works ok!
    ARC in Lago Vista, TX
    God gives every bird it's food, But He does not throw it into it's nest.
    - http://qliner.com
    edited 2000-05-03 03:53
    You're asking the wrong people that question. I only calls 'em as I sees
    'em.
    edited 2000-05-03 09:47
    Hi,
    I have a problem that might be ralated to yours.
    I have posted it, and it is Number 1422 "Problem with download"
    It might give you a lead, or check any replies to that posting as
    they might help you.
    Good luck to you,
    Hans
    my
    EEPROM
    edited 2003-04-14 13:43
    Hi, everybody. I´m new in this group and forgive me for something that can go
    wrong from me.
    I bought my Basic Stamp some years ago and now I´m trying to make it work again.
    However, when I try to run
    a program, wrote on my PC, I receive the message: "ERROR EEPROM verify failed".
    At the very begin I thought it could be an eeprom error (obvious!) but there´s
    an old program (perhaps 2 years old) running in the Stamp, because I can see the
    LEDs blinking on the protoboard.
    When I disconnect the cable that link my PC to the basic stamp, I got the
    message: HARDWARE NOT PRESENT (or something alike).
    Could somebody help me, please? Thank you very much in advance.
    zenito
    wrong from me.
    zenito
