Problem with serial port and my BS2
Thank you for reading this message
I use the BS2 for the first time. I have plugged my BS2 in the serial
port Com 2 (25 pins) and I use an adaptor (25 pins to 9 pins) to plug
in my carrier board.
So all the time I receive the same error message:"Basic Stamp ll
detected but not responding on Com 2....Check your power supplied"
The battery is new, the shop assistant check my computer and every
thing is ok.
Now, thank you to reply.
Sorry my English is very simple.
Pierre
thing is ok.
Pierre
operate correctly. Many adapters do not present DTR correctly. Also if the
adapter crosses RX and TX it will not work.
Your english is fine.
Al Williams
AWC
*Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
Original Message
> From: beljoie@d... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7wttssonw9w2XhdlD86QGBx40LDvPgnjIP9Qr9z06-DkHHZprYW6E9FWOP5Gk6K2xELUXD1P3eUvsQ]beljoie@d...[/url
> Sent: Wednesday, April 19, 2000 9:36 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Problem with serial port and my BS2
> thing is ok.
> Pierre
